My machine is reading RAD FAIL so there is no wireless connection. I am not sure how to fix this.
SOURCE: how do you reset lost password on Nurit 8020
Power down the unit and with your right hand hold down the 1 5 9 and enter keys down. While those keys are pressed down with your left hand turn on unit it should take you to that nos loader menu. Once in the nos loader menu choose back to NOS password is 1947. Once in the NOS menu choose number 6 Service Menu
then 1 Hardware test
then 15 RAM test this will state this terminal will self destruct continue. Hit enter and it will create a new RAM disk once you see the date & time if correct hit ESCAPE if not correct D & T hit enter then put the correct info in Military time MM/DD/YY format. Hit enter and it will take you back to your main screen with the original password of MMDDYYYY that is your password.
SOURCE: I have a verifone nurit 8020, When i go to reset
i had the program that resolved the tamper and tampering problem if you like you can add to you messenger thanks....
[email protected]
SOURCE: dropped my nurit 8020 on
The unit has in it a small, mechanical integrity sensor - one that constantly checks the position and fitting of the external case.
In your case it got triggered when you dropped the reader. If after you press the enter key to cancel the alarm nothing happens then the sensor is still triggered.
To fix that the case must be opened and the sensor reset mechanically. This is something only the repair shop of a dealer can do, you will have to take it to one. And no, your unit is not a goner.
SOURCE: I have a Nurit 8020
The internal battery must be replaced. Can be done by a specialized repair center and after that the operating system program must be re-loaded. Call this tel for a repair quote and mention FIXYA. (805)497-6265 (9am-4pm California PACIFIC time zone )
SOURCE: I have a verifone Nurit
Nurit OSP Loader is the the program we use to remove the TAMPER error. Replacing the internel battery and reloading a fresh NOS (nurit operating system) will remove the error. Check our website at freshpoint.org or cal us if you can at (775)358-2922 ask for Randy. It can be fixed, you dont need to replace it. thank you.
