Baby Gear Logo
Posted on Jan 04, 2009
Second hand stuck but other hands moving
Clock is probably past 2-year warranty - is keeping good time but yesterday second hand got stuck at number 9 and kept wiggling but not moving forward. I took it down and banged it a little and it moved on but then got stuck at 9 again. Any suggestions?
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Jan 04, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
Helped
10296
Points
38
It will be good if you replace the watch or get it repaired before the warranty expires.
Please rate my solution...
Thanks.
Mzasa
I have had a musical cuckoo clock for many years. probably two or three times I have had to have it repaired because the minute hands gets stuck at about ten till the hour. It will not move.
Taking care of the grandkids kinda tells it all, Never a good idea, unless you like buying new ones. OR paying for the repair. Maybe its time for a lesson in patience with the grands?
Mar 01, 2019 • Home
How do I synchronize a Grandfather Clock to chime correctly on the right hour?
Count the number of times the clock strikes, while leaving the minute hand pointing at the twelve, move the hour hand ( short hand) to the number it struck. ( this is the only time you should ever move the hour hand yourself). Tighten the hour hand by pressing the hour hand in towards the dial just a little. This can be done by placing a thumb nail on each side of the base of the hour hand at the center shaft. You do not want the hand to touch the dial. Now run your clock up to a quarter after, and let it chime. Now the half hour, the third quarter, and finally the hour. It should strike the correct hour if done correctly. Short version, move minute hand(long hand) to twelve so that it's pointing straight up. 2 move hour hand(short hand) back one hour. 3 tighten hour hand by pushing in toward dial. 4 check the function by advancing the clock one quarter hour at a time letting it chime in between quarters, then counting the strike on the hour. Hope this helps, and not confuses. Good Luck
Mar 02, 2015 • Home
How to adjust a Hermle grandfather clock?
you can try this although it may not work with your movement: set the clock at 9 and then move the hands forward past the 12 position. count the strikes. move the hands backward to the 9 position and then advance forward to the 12 position. count the strikes. did the strikes increase by one? if so, keep doing the same thing until your get 12 strikes when you are on the 12. then you can move forward and set the correct time and have the correct # of strikes.
Jul 25, 2013 • Watches
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 • Watches
1helpful
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 • Watches
Second hand is moving but doesnt keep the time
If the second hand is moving and the watch isnt keeping time then the movement needs to be replaced because it probably needs repair. The reason i suggest replacing the movement is becuase of the low cost compared to repair. You can try to submit to Diesel under warranty but need to check the terms.
3helpful
2answers
Changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
58helpful
7answers
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
