Question about Home
How do I synchronize a Grandfather Clock to chime correctly on the right hour?
Chime is off by one hour. Chimes ring one hour less that the time recorded
Tony Bowker
    New Friend:
  • 30 Answers
Count the number of times the clock strikes, while leaving the minute hand pointing at the twelve, move the hour hand ( short hand) to the number it struck. ( this is the only time you should ever move the hour hand yourself). Tighten the hour hand by pressing the hour hand in towards the dial just a little. This can be done by placing a thumb nail on each side of the base of the hour hand at the center shaft. You do not want the hand to touch the dial. Now run your clock up to a quarter after, and let it chime. Now the half hour, the third quarter, and finally the hour. It should strike the correct hour if done correctly. Short version, move minute hand(long hand) to twelve so that it's pointing straight up. 2 move hour hand(short hand) back one hour. 3 tighten hour hand by pushing in toward dial. 4 check the function by advancing the clock one quarter hour at a time letting it chime in between quarters, then counting the strike on the hour. Hope this helps, and not confuses. Good Luck
Posted on Mar 04, 2015
Clock chimes on the 1/4, but hour chimes just once. When i use the lever on the side, it will chime the proper hour, but when the clock is running only the one time on the hour.
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Jan 18, 2017 | Chime Home
It wont chime on the hour
Basic assumption... The chimes know what time it is...!!
FORCE NOTHING...!!
From page 10 of owners manual below (MINUTES):
EXAMPLE: Clock chimes at 1:10 but should chime at 1:15.
Step 1: When clock chimes at 1:10 stop the pendulum and record the time of 1:10.
Step 2: Carefully remove the small nut....
(Hour procedure is on the SAME PAGE (10).
WARRANTY INSTRUCTION MANUALS
Apr 19, 2016 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
NEED DIRECTIONS FOR CHIME
clocks chime the hour
what is the point of having a clock that chimes every 2 hours because you will not know how long it was from the last chime or be able to calculate the time between chimes
Dec 28, 2015 | Watches
How do I stop the continuous hour chimes on a WESTMINSTER chime mantel clock ?
Is this a older type mantel clock or an electric. A older one has a small arm on the back of the wooden case just move it to it's opposite position and that should stop all chimes. A few times that small switch is on the inside but very rear. If it's electric it also should have a switch to turn off all chimes.
Feb 06, 2015 | Home
How to adjust Grandfather clock that chimes one chime less ?
Move the hour hand counter clock wise to 10 o'clock. Then turn the minute hand clock wise to set the correct time.
Main Page
Oct 04, 2014 | Home
Clock Manuals
leave it running when it gets to 12 oclock it wiil reset itself
May 02, 2013 | Watches
The chime of my Howard Miller mantle clock are not w/the actual hour set.How can I reset the chimes? Daylight Savings time has messed me up.
Nov 06, 2011 | Seiko Mantel Clock
How do i synchronize my chimes on a westminster quartz abacus 401c wall clock
If it is like mine you press the test button until you hear the chime. Wait for the hour chime to go and count it. If it chimes once for 1PM and you need it set to 6PM then you press the test button to reset the chime and repeat press the button 5 times. This will set the chime to 6 PM. If you get lost on the time press until it makes no noise. This means you are 11PM or later and continue to then press until it makes noise again. Count the hour chimes and you are at the count in the AM. Repeat the steps and keep pressing to get to the proper AM or PM hour count..
Jan 16, 2011 | Watches
Timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Oct 04, 2008 | Watches
Home Logo
420 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
