Question about Watches
How do I set the Chimes on the Ergo Westminster Clock
Bradford McMillan
    New Friend:
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Posted on Mar 04, 2017
5 Related Answers
Anonymous
SOURCE: Whitting and Westminster Jean luis Electronic clock
I found my own solution through trial and error. I set the dials to 12 00 and then move the dials to show just over 5 minuites to 12 ( 1155) the alarm melody start and chimes for a number ( in may case it was one.) then i moved the dial back to 1200 and then reset it again to 1155 or just over. Each time the alarm chimes an increasing number
I had the clock chime settings on the back of the clock to the middle setting (chimes on 24 hours)
I carried out this until the chime was right for the time i was working ( in my case it was 1730) so when it reached 5 chines I then set proper time and left it. The next chime was correct
Posted on Jan 12, 2009
Anonymous
SOURCE: seiko mantle clock (switchable chimes)
See this site
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Apr 22, 2009
Anonymous
  • 15 Answers
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Posted on May 10, 2010
Anonymous
  • 5 Answers
SOURCE: Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
Posted on Jun 05, 2010
Anonymous
SOURCE: Elgin Westminster Quartz Chime clock won't work
IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
HOPE THIS HELPS.
Posted on Oct 11, 2010
Clock Manuals
leave it running when it gets to 12 oclock it wiil reset itself
May 02, 2013 | Watches
How to syncronize time with clock chimes? Howard Miller banjo clock.
The hands on your clock are probably friction fit, meaning that they can be adjusted, possibly even without tools. The hour hand is usually a firm slip fit over a tube, meaning that it can be slid forward and backward an hour or more as long as you hold the minute hand steady to keep the hour shaft from turning.
The minute hand may be trickier to adjust. Sometimes, it, too, is a simple friction fit, and you can pop off the hand (remove the second hand and pull the minute hand straight up off its shaft) before setting it where it should go. Other times, however, the minute hand is on a keyed shaft and has to go on in one of two directions. It's still possible that someone could have assembled your clock incorrectly, however, making the minute hand 30 minutes out of sync with your chimes.
If neither of these ideas helps you, please describe better exactly how the time isn't matching up with the chimes. That will help us better understand the underlying issue.
May 09, 2011 | Watches
I have a Revere 913 clock. Keeps perfect time. Westminster chimes only work intermittantly by itself. Can activate chimes manually. It appears that the functions are in order, but will not activate by...
Hello Rterry6517,
Yes... you are right (CLOCKSMITH / movements).
Electric movements (original (telechron chiming type))
are very much the same as SPRING DRIVEN...
(in fact... the ones I have worked ARE spring driven
Merely THE WINDER is ELECTRIC)).
A CLOCK repair would be the wise choice...
Some people opt for the electronic conversions...
(my opinion they are quite a bit less of the true tones
of a well maintained clock motor and REAL CHIMES.
Hope THIS HELPS...
Carnac the Magnificent
Nov 20, 2017 | Watches
How do i synchronize my chimes on a westminster quartz abacus 401c wall clock
If it is like mine you press the test button until you hear the chime. Wait for the hour chime to go and count it. If it chimes once for 1PM and you need it set to 6PM then you press the test button to reset the chime and repeat press the button 5 times. This will set the chime to 6 PM. If you get lost on the time press until it makes no noise. This means you are 11PM or later and continue to then press until it makes noise again. Count the hour chimes and you are at the count in the AM. Repeat the steps and keep pressing to get to the proper AM or PM hour count..
Jan 16, 2011 | Watches
We have a Acctim barrery operated westminster chime wall clock and cannot get the clock to work, pendulum & chimes work but not the clock, is there a reset button,how do we get it working. it is 11yrs...
Press the red button at the back and go through all the hourly chimes until you get to the next chime due i.e. if its 3.15 whebn your doing this, only go through the chimes until 3 o'clock and no further. Then turn the hands clockwise ONLY never anticlockwide and she should be fine.
Nov 19, 2010 | Watches
I have a Seth Thomas Grandfather clock with three different chimes and chimes at every 15 minutes. The problem is it is chiming 2 hours shorter than the actual time. Example say it is 11:00, it is...
Thanks for contacting FixYa.
I wish I had an aswer for you but I dont. Here is a link for a repair man that has an 800 # toll free to call for estimate.
http://clock-repair.net/site-map/seth-thomas-clock-repair/
Best regards. Jewel
Sep 13, 2010 | Watches
Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Apr 21, 2010 | Watches
Timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Oct 04, 2008 | Watches
Watches Logo
2,277 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
