This phone has worked all right for 1 1/2 year. It is connected to an ADSL access point and has a separate IP-number on the network. It is prepared for Skype via USB, but this feature has never been in use. The serial no. 0511032179 is labelled on the docking. Olympia Du@lphone is Lately it has been impossible to make phone calls or receive phone calls from the wireless handset. The message "Ready Line in use" is displayed continously. Beeps from the phone is received when any button is pressed. Battery has been removed and replaced. No reset-button is discovered. No online manual is discovered. This forum is my last hope. HP Hoeie, Norway.
SOURCE: Keypad not working during phone call
If sounds like DTMF is turned off on your phone. If it is then it is not sending the correct tone over the air which is why nothing happens. Go into setting, then to initial setup and key down toward the bottom and you should see DTMF if it is off change it to short or long and that should correct you problem.
SOURCE: no dial tone on handsets
Hey.. Did you check to see if the phone is registered correctly ???
SOURCE: Olympia, and/or Sharper Image infoglobe. Need fix.
olympia infoglobe model OL3000.2 stopped showing display.
The center spins yet no information is displayed
