My laptop monitor has a large black blotch in the upper left hand corner. It affects everything on the screen below it. There are horizontal lines. Can it be fixed?
Agree but if you don't mind the black spot keep it. Replacing the LCD is not difficult as long as you have the patience and small screw drivers and you need an assistant to hold the LCD while installing it/
Also buy anti-static gloves from an electronic store
Sounds like the LCD has sustained physical damage. Replacement is the normal solution.
Monitor Mike
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Please leave a vote if you like my answer
