The large screen monitor is hooked up to my laptop. The 17 inch LCD monitor is a NU. The screen on the laptop is fine. The LCD monitor has started to shift to the left. At the moment there is a black band about an inch wide on the right hand side of the screen. Part of the left hand side of the screen cannot be read. If the monitor is left on the screen seems to gradually shift to the left. I tried to drag the screen but that did not work. Any suggestions you can give would be much appreciated. As a technopeasant of the first order please give very simple information when you response. Thanks in advance.
Penny
SOURCE: MONITOR PROBLEM
If you have a digital monitor, press the menu button on the front of it and adjust H size and centering. Failing this, try changing your refresh rate in Display settings>>Settings>>Advanced. Failing this..you have a bad power supply in your monitor.
SOURCE: ViewSonic VE710B - 17" LCD Monitor
this is purely a monitor issue it has nothing to do with the drivers in windows. there is likely damaged boards in the monitor itself hard to say what with the description you give. need to be serviced in a shop
SOURCE: Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
SOURCE: How to use this Proview LCD Monitor 17" 700P AS A TV Screen
No. The newer LCDs can do both. But they are a TV to start with the option to hook up a Desktop.
