SOURCE: White screen
You have an IF problem or a problem in the video driver circuit. If there is no sound I would tend to think there was an IF fault. No quickly fix here I'm afraid. Most likely this set will not be worth fixing. Good Luck
SOURCE: No picture
It sounds Like you Had Horz Failure In your Set,The Squealing you Heard was Probly the Horz Output Transistor,You will Probley have to take it to a Shop
SOURCE: Insignia IS-TV040919 color problem
The tv has been dropped or banged around, you can try to get a degaussing coil and fix the colors, if you cant pull them back out than it would need a CRT/Picture tube...in other words the tv would not be worth anything.
SOURCE: Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
SOURCE: no power
Have you checked the outlet for power if so open up set to see if fuse came out during moving it if fuse checks ok look for cold solder joints in power supply [email protected]
