I have the Insignia NS-L26Q-10A26"LCD TV. I've had it for months. Suddenly today the TV would...
(More)
I have the Insignia NS-L26Q-10A26"LCD TV. I've had it for months. Suddenly today the TV would not go on. It just says "no signal". I tried going to "input" where you set it to TV, VGA etc, to make sure it was set to "TV" and it is. I tried using the same cable on another TV and the signal is fine. I then tried using the insignia TV as a monitor to see if there was any problems with the picture. And it works fine as a monitor. SO as it stands it's not a problem with the cable, it is set on "TV" and also the picture is fine when it is used as my monitor. Also nothing happened to the TV since last night when I was watching it, and this afternoon when I turned it on. It's on the wall so it wasn't inadvertently hit into or anything. This just doesn't make sense. Does anyone have any ideas of what might be happening or what I could do ?! I just bought this thing a few months ago! It's not like it's had a long life. It's actually probably not covered by warranty anymore since most of them are only up to 3motnhs or so... Don't tell me this is one of those pieces of **** that's made to brake down after the warranty is no longer any good.:(
My other HD LCD TV shows HD channels filling the screen and LD (low-def) channels filling a 4x3...
(More)
My other HD LCD TV shows HD channels filling the screen and LD (low-def) channels filling a 4x3 rectangle in the middle of the screen filling the screen vertically and leaving a black area on either side. This TV has several "zoom" settings none of which act like the other TV. You either get all channels short and fat (HD is compressed), or all channels long and thin (LD is stretched). For now I leave it on the "Zoom" setting that was the default, leaving LD channels distorted. Is there a better setting or combination of settings that I haven't found?
please can you take me step by step through retuning my samsung so that iam able to recieve channel...
(More)
please can you take me step by step through retuning my samsung so that iam able to recieve channel 5
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
