SOURCE: Edirol UA 4FX _Short Audio Signal dropout
try runing a cleaner ccleaner and ace utituies ok that stop those hickups give a atry make pc run alsot faster
SOURCE: Recording Device Not Listed
You need to install the driver accordingly, When you buy the product it
comes with installation Disk. If you dont have it now still you have
solution simply download the driver from the manufacturer's website
Here is the link
http://www.rolandus.com/products/productdetails.aspx?ObjectId=758&ParentId=114#
Good Luck
SOURCE: Synthogy Ivory italian Grand won't play with Edirol UA-4FX sound card
try to see the connections of your device to your computer and see also the troubleshooting on manuals. then try it to another computer if still the same as the previous computer.
CHARCOIS
SOURCE: Edirol ua-4fx Synthogy Italian Grand problem
What operating system are you using? It appears, based on other experiences, that the Synthogy UA-4FX fails to function on Windows XP once SP3 has been installed. Is this your situation? If so, uninstall SP3, and you should be set. However, as you installed a new driver, that may come into play if it does not reach a functional state. Further, there are often problems with other devices when this is the case. So, if it is a recent purchase, as it seems from your presentation, it may be a faulty piece of hardware. If this is not your situation, please post back with further detail regarding the PC/OS and other equipment & drivers you have in place. Good luck!
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
SOURCE: No sound out from input
It's probably your computer, more specifically the type of application you're running it on/in. Also, when you install or fiddle with the settings, you have to be careful because it can be so confusing fixinfg them.
