Toshiba Laptop Won't power on at all, the power AC and the battery lights will show up, on the front but when I push the Power Button, it won't start up at all, and both those lights "go out." Does this mean a trip to a laptop repair center?
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Windows won't start up ? Well, try this
Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting.It can make sure your important data will not lose.
Best of luck
SOURCE: tosibha qosmio f15 av201 does not turn on when power button pressed
i am no whizz, but i think, just THINK maybe you should get some friend or relative to check the wiring to the fan and the power button, maybe when cleaning the fan, the wires were losen, as the button is millimeters away from the fan.
i hope it might help, if not i already said, i'm no whizz
SOURCE: My laptop wont start
my suggection is that the element has gone so it would be cheaper for you to take it to the shop for repair.
SOURCE: Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Testimonial: "First step in a series to diagnose. On the journey. Useful thanks."
SOURCE: My laptop won't turn on,
Good day. You can try to do these steps which is usually a normal solution to this kind of issue:
1. Take out the battery of your laptop
2. Remove main supply, or power cord
3. Hold power button down for 30 secs,
4. Put only power supply in or power cord
Note: do not put battery in yet
5. Turn laptop on
6. Put the battery in.
If this will not work you might consider contacting toshiba tech support for laptop for other resolution. Hope this information will be helpful in resolving your issue. Thanks for using fixya and have a great day.
SOURCE: Toshiba Satellite C655-S5082. Won't power
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Gave up on the Toshiba, A305 model laptop, found out it was not a power button problem, it had a faulty Motherboard, so off to a Recycle bin it's going, thank you very much for everyone's help here though (smiles). I took it into a repair shop and they said the Motherboard was toast, and there was no replacement one's that could be purchased at all.
