Water pressure problems can be caused by a number of different things.
First you should find out if anyone else in your area is having the same issue. If it is an issue with the water system in your area then you wont be the only one experiencing this.
The lack of water pressure could also be an issue with your homes plumbing.
Either way it can be an expensive fix. For city water pressure problems you may have to get a pressure pump in order to increase your water pressure
Are you having low water pressure to whole house
hi, no we are not , only to the new kitchen tap. The old sink/tap has been placed outside the house and that's fine to use also
