Tried to reset, still not working.
SOURCE: TI-83 Plus Silver Edition 1.14
That means that you know your calc crashed. This can be caused by taking out the batteries durring running time, happened just randomly. Well nothing to fear just press clear and it should go away but if it stays on that screen you have problems and is best to try some of these methods. Take out all the bateries and press and hold the on button for 30 seconds. Put the batteries back in and it should have reset. Warning you should archive everything incase this happens. To archive go to 2nd mem and hit enter to put a astrick next to the app (meaning archived)
SOURCE: TI-83 Plus No Longer Squares Correctly
when you type -2 imagine your calculator doing the equation: -1 x 2. The - sign actually stands for a -1 so when you do -2 squared your calculator is simply following order of operations. It first squares the 2 making it 4, then it multiplies the negative making it -4. In order to get around this you must use parenthese. (-2)^2.
Hope this helped
SOURCE: Find the antilog on the TI-83 Plus for finding pH in chemistry problems
I reccently had the same problem, but I have a Ti-84 Plus,and I am disgusted by how poorly this matter is covered by Texas Intruments. Esp. since the solution is rather simple.
The antilog key is [2nd] [log] or the 10^x. On your screen it should apear as 10^( and then you just input the value that you want to find the antilog of.
When used to solve pH problems remember to input the pH value as a negative number, since pH= -log[H+] then [H+]= antilog(-pH).
Hope that helped))))) ^^
SOURCE: TI-83 Plus calculator--fractions
just type it in, e.g. 1/2 or 3/5. if you want to have answers display as fractions, press [MATH] ENTER.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1). Try a new set of AAA batteries. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system. Try a new set of AAA batteries. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
(Procedure 2).
~Connect the TI Connectivity cable between the PC and the calculator.
~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
