Switch source to DVD, then the lower buttons hit the button with arrow pointing up. Or the eject on tv.
Tried to unplugged and re plugged the unit and push eject button. if can not get with reset at this time you are going to remove the cover then access the internal part of the dvd player. check for an stuck up in the cd tray mechanical assembly.
SOURCE: dvd player
SOME dvd players have a small hole in the front... just large enough for an opened up paper clip to fit into. If yours has this, unplug your machine and insert an unfolded paper clip into this hole and gently press the mechanical eject switch. If you don't have this feature, your only hope is to disassemble the bottom of your set and spin the eject motor by hand to remove your disk.
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
SOURCE: I need the remote control code for Proscan tv with dvd player
Don't know if the 26" is the same as the 32, but 10019 works for the 32".
Technician's Assistant: Can you guesstimate how old your Proscan is? And just to clarify, what's the exact model?
The remote does not seem to have an eject key.
Technician's Assistant: Does the TV menu work? Do you have the same problem with all sources/inputs?
The menu seems to work, but it does not seem to show an eject key either.
Technician's Assistant: How long has this been an issue? What happened right before this popped up?
We recently purchased this TV. The first DVD is still in the slot because we cannot determine how to eject it.
