I want to know if I can use my gps overseas and download new area maps
You may download the manual from here.
SOURCE: Garmin nuvi 260
Re: Not sayinstreet names.
After you turn on your unit touch the wrench icon in the bottom right of the screen, this will take you to a menu which features "Settings" in the upper left of the screen. Touch "settings" and scroll down to "language" by using the up and down buttons in the lower right of the screen (down 1 should do it). Touch "Language" and in the voice category find and select "American English - Jill (TTS)". This is the voice that will give you Text To Speech (TTS) speaking the street names in English. If you prefer Spanish or French, find the appropriate catergories with "(TTS)" beside them - "Espanol Americas - Paulina (TTS)" and "Francais Canadien - Julie (TTS)" respectively. Any other selection will only give directional instructions such as "turn left in XXX".
After you have selected your voice press "OK" and back out to your main menu showing "Where to?" and View Map".
Now, when you navigate, you should hear an American female voice giving you directions by street name - assuming your volume is high enough to hear it.
RE: The computer icon displaying when you try to use your unit in the car with the 12 VDC cord.
You probably have a problem with the cord. The pin length in the USB style connector is critical and if it doesn't match up just right the GPS thinks it is hooked up to a computer. If you know someone who has a Garmin NUVI try using their cord and see if you have the same problem. Either way, call Garmin and see if they will send you a replacement cord or otherwise help fix the problem.
SOURCE: My Garmin Nuvi 255w Car Gps
You must call Garmin at 1-800-800-1020 they will walk you through plugging in nuvi to your computer (must have usb cord) and it will upload then go to my computer and choose garmin drive then click garmin folder and either find the folder they say or make new one like I did with the guy on the phone and put in code. The only information needed is the numbers on the bottom of the device.... super fast fix!
SOURCE: Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
SOURCE: Need Garmin nuvi 855 manual
Your manual for your Garmin Nuvi 855 can be found at this following manufacturer link:
http://www8.garmin.com/support/userManual.jsp?market=4&subcategory=41&product=010-00577-31
Please be sure to vote if this was helpful to you.
Regards,
Joe
