20 Most Recent
Garmin nuvi 1200 Car GPS Receiver Questions & Answers
Screen is stuck on loading
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
- The device powers on and freezes at the Garmin logo with no trademark or copywrite info displayed on the device which normally shows up below the logo. The device will not display the Main Menu and will not go into Mass Storage Mode.
- The device powers on and freezes at the Garmin logo and then flashes a white screen briefly. The device then begins a loop of showing the Garmin logo and then flashes the white screen over and over again. The device will not display the Main Menu and will not go into Mass Storage Mode.
- The device powers on and then freezes or shuts down when displaying the Loading Maps screen.
For service/repair of a device due to the three symptoms listed above please select
"No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
- Market Name: On the Road
- Serial Number (listed on the bottom of the device)
- Question Type: Repair Information
- Provide a short description of your problem or question: nuvi frozen on Garmin Logo
- Full Name
- Contact Phone Number
- Shipping Address
Garmin nuvi 1200 wont let me type the right letters
Try recalibrating the touchscreen. The procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1315261162Turn
off the Nuvi. Place your finger on the upper left-hand corner of the
screen and then push down on the power button to turn the unit on.
Release the power button when the Garmin logo appears. Continue to press
on the upper left-hand corner of the screen until you see the
calibration screen. Press each dot to recalibrate the screen.Once completed the Nuvi will display Calibration Complete
MAC cannot find device Garmin
Hello Svanefalk,
Maybe this will help you some. I have found you the complete manual
which covers most of the models of the Garmin Nuvi. It is the full
manual from start to finish with complete operating procedures as well
as schematics, operation instructions complete with pictures, and
trouble shooting section and even other contact numbers to deal direct
with Garmin, if your model is not covered in this manual.
Here is the link for you:
http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
Also if you can, please rate my solution if you can and some kind words
would be appreciated. I also took the liberty to put my link at the
bottom of this page that directs you to my personal page for all my
areas of expertize, such as Automotive, Appliance, Electronics. Feel
free to check it out anytime and save my link for future problem. Thanks
So, Much Mike.
http://beta.fixya.com/users/mc1bean
I have a Garmin nuvi
Try doing a reset on the nuvi by pressing and holding the power button on for at least 10 seconds.
Installing and running the Garmin WebUpdater and reloading the latest update will resolve most issues.
Download and Install WebUpdater.
Garmin Nuvi 1200 does not have a qwerty keyboard,
I have a Nuvi 1100 and I added the qwerty keyboard editing the british english keyboard file(en_GB.kbd). Open it with wordpad and change the "true" with a "false" like this:
<group name="QWERTY" priority="1" wide_screen_only="false">
Then, go to tools, settings, language and change it to british english and you are done!
Att. J. Martinez
When turning on our Barmin
You can try to reset the 1200. You can reset by pressing and holding the power button until it reboots.
If that does not work you can try a hard reset but it will clear out some of your favorites and saved locations back to like when it was new.
Power off the unit; then while holding your finger on the lower right
corner of the screen while turning it back on.
Keep your finger pressed until a window appears. Choose YES to clear all data and return the 1200 back to factory settings. I will attach the Garmin customer support info.
Thanks for using FixYa.
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
I HAVE A NUVI 1200.
It sounds liek your unit may be defective I would reccommend trying to give it a firmware update using Garmins WebUpdater Software. If you are not able to connect it to the PC it would have to be sent in for warranty or repair. Here is a
link to the Garmin software.
Hope this helps!
I just took my Garmin
No power at all?
Check your lighter socket to see if it's getting power (plug lighter in and see if it gets hot).
Check the power plug on the provided cable. It contacts a fuse that may either be missing or blown. And last, check the connection of the cable as it plugs in the rear of the Nuvi.
I was driving home today and our Nuvi1200 said it
The connectors are alway a weak point on these devices, you need to check the lead is ok and that the power is on on your cigarette lighter socket. Also worth checking the fuse in it if not.
Murphys law is things will always fail at the worst possible time.
When you are home check that the device can be powered by your computer or a charger.
Then you will know if its the lead or device.
Please dont forget to vote this answer was helpful
Many thanks
We have a Garmin Nuvi
If the problem persists after the reset to factory setting then hard fault is present in the GPS circuitry and this will require the GPS be sent back to Garmin for service and repair, they offer an exchange service to speed up down time. Below is the service contact number for Garmin. The cost to repair is available there as well.
http://www8.garmin.com/support/outofwarranty.html
