20 Most Recent Garmin nuvi 1300 Car GPS Receiver Questions & Answers
Your software is corrupted. If you contact Garmin they will replace it for you with a refurbished unit for less dinero than getting a new one.
Garmin nuvi 1300... | Answered on Jun 14, 2017
If you have registered your device on the Garmin site, it will show up under your account. If the unit was bought in 2009, it would not be under warranty and any remedial fixes that may have been available are probably no longer offered 8 years later. Garmin support does do both warranty and non warranty work. You are probably better off buying a new unit,
Garmin nuvi 1300... | Answered on Jun 02, 2017
In the Nuvi 1300 Bluetooth controls can be found in Tools - Settings - Bluetooth.
In this screen the Bluetooth communication mode can be switched on/off by pressing on the Bluetooth menu entry. Press Off and Save to store this setting.
Also existing (paired) connections with a cellphone can be dropped by pressing the phone menu entry and press the delete button.
Garmin nuvi 1300... | Answered on Jan 13, 2017
To activate your Bluetooth, touch Tool>>Settings>Bluetooth.
For Bluetooth connection, touch the button to pair a Bluetooth device with wireless technology or any device you want to connect with. To disconnect from other Bluetooth device, touch the drop from the screen. To wipe off the Bluetooth device you paired to your nuvi, Touch remove from the nuvi paired list, and it will delete it from the nuvis memory.
Garmin nuvi 1300... | Answered on Jan 07, 2017
Try going into tools on the main screen then select help, then select settings and then bluetooth settings this may help you get your bluetooth set up but remember not all nuvi are set up for bluetooth
Garmin nuvi 1300... | Answered on Dec 17, 2016
Remove the power from unit while it is still on and then hold down the power button for about a minute. Reconnect to power source and see what happens. If still operating erratically then something is wrong with the electronics of the unit.
Garmin nuvi 1300... | Answered on Jun 13, 2016
www.mygarmin.com
profile your account there and make any changes
Garmin nuvi 1300... | Answered on Mar 31, 2016
Hi I own a garmin with life time of maps, You need to connect your garmin to your computer with a usb cable and your computer with automatically set it up and check for up dates.... Hope this helps...CHEERS..
Garmin nuvi 1300... | Answered on Mar 15, 2016
You need to find a power outlet in your car that is controlled by your ignition. It sounds like the outlet is on at all times. This will keep you Nuvi constantly powered.
Garmin nuvi 1300... | Answered on Feb 29, 2016
Reconnect to gatmin express, go to change map, chNge region from NW to NE. Map file too big for entire USA unless you use an SD card.
Garmin nuvi 1300... | Answered on Jan 29, 2016
Re-install both the maps and main software through Garmin Express and your PC. Probably more than once or twice before it "takes".
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Garmin nuvi 1300... | Answered on Dec 14, 2015
Check the map on the unit. Make sure that there is a check mark next to the map that you want to use. Make sure that the map is from the region that you are in. If the map says "2016 City Navigator US Lower 40 States NW" then the map will only cover Northwest (NW) and not the area in the East.
Garmin nuvi 1300... | Answered on Nov 11, 2015
Garmin nuvi 1300 Car GPS Receiver Logo
698 questions posted
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
nuvi Garmin
  • nuvi Garmin
Most Popular Question
screen only shows press dot when dot
  • GPS
