Tip & How-To about Garmin n?vi 265WT Car GPS Receiver
Nuvi 265WT Delete Phone Numbers
Garmin Nuvi 265WT Delete Phone Numbers
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to erase the phonebook entries on your Garmin Nuvi 265WT, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 265WT.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
____________________________________________
Change Nuvi 265WT Home Phone Number here.
Download Nuvi 265WT Manuals here.
Download Garmin Nuvi 265WT WebUpdater here.
Garmin Nuvi 265WT Hard Reset here.
Garmin n?vi 265WT Car GPS Receiver Logo
how delete the home phone number
I can help you edit your Nuvi 265 home phone number.
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
Erase Nuvi 265WT Phone Numbers here.
Backup your Nuvi 265WT Favorites here.
Dec 24, 2009 | Garmin nuvi 265 Car GPS Receiver
garmin 265wt. How do you delete duplicate # fm phonebook?
I can help you with the phone numbers on your Garmin Nuvi 265WT.
I hope that helps.
Feb 10, 2009 | Garmin nuvi 265 Car GPS Receiver
3,362 people viewed this tip
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
