1994 BMW 3 Series Logo
chris burt Posted on Sep 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my 1994 bmw 316 coupe temparature gauge rise and fall
When im driving the tempareture gauge keeps going half way then back down to cold evan when engine hot also heaters only blow hot every now again, cars not losing any water what could this be?
vegas devildog
Level 3:
Master:
  • Master 373 Answers
  • Posted on Sep 19, 2012
vegas devildog
Master
Level 3:
Master:
Answers
373
Questions
0
Helped
111684
Points
1049
That is normal when it start going into the red that is bad
5 Related Answers
Richard Jordaan
  • 10 Answers
  • Posted on Jul 18, 2008
SOURCE: bmw 316 e36
change your fuel filter if it does'nt work check that your fuel pressure is ok if not check that all the plugs on your air intake is all good and pluged in properly
Anonymous
  • 116 Answers
  • Posted on Dec 11, 2008
SOURCE: BMW 325xi 04 Heater Fan working (sound) but not blowing any air.
motor is going bad replace it
Tony Seward
  • 47 Answers
  • Posted on Mar 18, 2009
SOURCE: 97 BMW 316 Auto, using alot of engine coolant, no signs of leaks
Check exhaust, sounds like a small head gasket leak.
Anonymous
  • 832 Answers
  • Posted on Oct 09, 2009
SOURCE: 1994 bmw 325tds se m51 engine won't start when its
You got a case of an overheated engine. Give your
radiator an overhaul so that your car can breath well.
Also check water temperature sensor for defect. Okey,
give us a feedback thru e-mail.
Anonymous
  • Posted on Jan 06, 2010
SOURCE: My 97 BMW Z3 keeps overheating
I too had similar problem when replacing the thermostat on my Z3. My advice is top up with more coolant and check the level.
2001 Honda CR-V LX Temperature gauge rising
The ac fan only comes on when the ac is on , the engine fan comes on at engine operating temp . few things to check , the radiator core fins are free from rubbish leave or plastic bags , the thermostat is fully open , radiator tubes are blocked with gunk have it flow tested .
I have a 1993 mercury' marquis. The floor boads of the front part of the car get hot. And the thermostat keeps falling to c and rising to half way and falling on gage. Can u please help?! Thanks
possible no water in the engine and it is overheating
this is indicated by the temp gauge rising and falling
temp gauge sender units need to be immersed in water full time to get a reading so if it goes up that is in water and when it falls back that is in nothing or steam
hot engine would account for hot floor
1helpful
L200 Warrior.Temp gauge rises then falls back to normal on driving.
The gauges rises fast and drops fast because there is air in the system. I would fill it first/purge the air out as it is running. If it still discharges on the floor, you might want to change the T stat and or water pump.
Temperature gauge cold then back to normal
You have to make sure the thermostat is working properly and is the correct one. Idle the vehicle for about 20 minutes and then feel the upper radiator hose. It should be hot to the touch. Drive the vehicle and when the temp gauge falls to 'cold' stop and feel it again. If it is much cooler to the touch than before the thermostat is defective or wrong.
Pressure in the AC keeps rising and falling.
was the pressure gauge connected to the discharge side or the suction side of the compressor
if you have it connected to the suction side , you have excessive gas in the system
2helpful
Hullo, I drive a 5 door 1.3ltr manual Ford Festiva. When the petrol tank is full the petrol reads full. When the petrol gauge reads around half full the petol gauge falls to zero. The petrol gauge will...
Your problem is the fuel gauge sending unit. It needs to be replaced. Another benefit of owning the durable festiva is the access panel under the back seat. You don't have to drop the tank to fix this problem.
3helpful
3answers
Temp gauge up and down
It is IMPORTANT That you Correct This ,as Engine Temp is Important. I Recomend the Coolant Temperture Sensor Be Replaced to Correct this.
Temp gauge 318 is BMW
Hi, this sounds like the thermostat may not be performing as it should, it may be worth removing it and checking to make sure that it is working correctly.
2003 SATURN VUE WITH GAUGES FALLING TO EMPY AND COLD SPARATICALLY
Stepper motors inside the insturment cluster . 2003 to 2006 gm had problem with bad stepper motors .
How to repair GM Instrument Cluster Speedometer Gauge Stepper
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
