Cursor lockup
This just because that there are too many services running in the background of the Operating system
All you need to do is to manually disable maximum of them and disable all the startup Items
Here is how you can do that the easy way
Manual steps to perform a clean boot in Windows XP
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click
to select the Don't show this message or launch the System
Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The
System Configuration Utility is currently in Diagnostic or Selective
Startup mode, causing this message to be displayed and the utility to
run every time Windows starts.
Choose the Normal Startup mode on
the General tab to start Windows normally and undo the changes you made
using the System Configuration Utility.
Step 4: Optional step to disable features
This
step temporarily disables Microsoft features such as Plug and Play,
networking, event logging, and error reporting. Also, this step
permanently removes the restore points from the computer. The System
Restore feature uses restore points to restore your computer to an
earlier state. If you remove the restore points, you can no longer
restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Steps to configure Windows to use a Normal startup state
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
I bunk up and my cursor makes a box that reshapes itself like in programs of art. When I try to get rid of the box, I get a drop down of various actions I can take==sometimes many drop downs. Wish I could be more clear.
Are you holding down the left mouse button while you are moving the mouse?
I think you are double clicking on your desktop and then right clicking to bring up a menu, is that correct?
What do you mean "boxes" and when you "bunk it up"? Explain the process you use to get your problem exactly.
