I use i for my dell desktop and my macbook pro i pulled out the fire wire wyile it was still plugged into the pc now it cant be recogninized both computer say no hardware connected the firewire is still poweing it up power lights on and the lkd nothing on the fw
SOURCE: my firewire does not connect to my firewire focusrite saffire
I had the same problem during instalation... Try connecting first and then connect the power cable. It worked for me and installed properly. The problem is I'm facing a new problem now... The Azmixer.exe -or something similar - won't load on memory... The sound card doesn't work and isn't recognized... Any idea...?
SOURCE: no sound device connected to pc!
Do you now have a solution for the problem coz I have the same poblem....
Your soonest reply will be appreciated! Thnx...
SOURCE: My Saffire Le doesn't show up in AUDIO DEVICES but
Go to Volume Controls - Options menu - Properties... is it in the Mixer drop down box there? You might find the problem is that any onboard soundcards you have on the motherboard are now set to default since you reinstalled. In which case go to device manager and disable it. If problem persists try a reinstall of saffire whilst the onboard card is disabled. Some motherboards allow you to disable the onboard sound from the bios menu too, that could be something to try
SOURCE: Hi I have just attempted a
In control panel audio set saffire as default.Also check that in audio properties you have speakers or headphones or whatever you using checked off.
If this doesnt work,uninstall your realtek program and drivers then reboot,this should force your saffire card to take over.
Last.. you may need to go into the bios and disable onboard sound,as a matter a fact do this first. the old soundblaster cards had the same issues.
