Pioneer SD-533HD5 53" Rear Projection HDTV Logo
Anonymous Posted on Aug 14, 2012
Pioneer Rear Projection TV problems
Pioneer Rear Projection TV. We brought one secondhand tonight, it seemed to have the red light at the front, but wont turn on. When power was unpluged and pluged back in, the red light came on, then went green, then back to red. I checked the power voltage on the back, was turned to 220 (its ment to be 240v here in NZ) tried it again, there was a pop, then a green spark\light inside the back, and now no red light or anything?
  • Anonymous Aug 15, 2012
    I have managed to find about 9 fuses (glass ones) inside the TV. The main power one had blown (it was black) the rest seem fine. there is a second fuse (says fuse2) that I pulled out, and tried it in were the other had blown. Turned tv on and the red light comes on, but pushing the 'on' button, it just 'clicks' in the back. I tried putting the fuse back were it came from (fuse2) but it wont let me now. The fuse is T6.3AL250V, the same as the fuse1. It gives me a 'pop' even with the tv unplugged from the wall. Now I cant get the fuse back in lol.
Anonymous
Level 2:
Sergeant:
  • Expert 186 Answers
  • Posted on Aug 14, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
186
Questions
Helped
75267
Points
522
A 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
    Thank you Kevin. So I should find the fuse (Do you know where inside it would be?) and replace it first? If I do that, then the TV does what it did before (red light, then green light, then back to red - sounds like a ticking sound when it does this) then it stays on red and wont turn on.
2 Related Answers
Anonymous
  • 5138 Answers
  • Posted on Feb 25, 2010
SOURCE: pioneer sd-532hds. the red light is on but when
STK ICS 2 of them replace Both STK392-110 use 180s Mats Electronics has them $10.95 each
1-800-628-1118
Anonymous
  • 7 Answers
  • Posted on Sep 15, 2010
SOURCE: Pioneer SD-532HD5 Projection Screen TV won't turn back on.
the problem with pioneer projection tvs is that when they made the boards they never used enough solder for the circuits and you get cracks in the runs. thats why heat and cold will effect it. I had the same problem and I took out the board and resoldered every track I could and it works good now but my remote wont work if anyone has any info or prints to this tv please post on here
1helpful
What's your problem?Pioneer PRO-530HD 53 in. Rear Projection Television flashing red standby light
This and a few other models like it have one real common issue:
they develop from age and heat bad solder connections all over the power board (rather large board).
My experience with them is the fix usually is remove rear cover and follow power cord to power board (a lot of plugs to mark) and remove that board----then solder every single connection on the board which by the way has some special fuses on it.
2answers
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
Red shadow?
call a tech and have them converge the tv.its either that or the focus
Red shadows of words on screen of projection TV
you have to go into the menue, and go under video settings, under advanced, then into convergence, when you get the white lines all over the screen, follow the directions and adjust the red so it lines back up, other wise , take the front bottom panel off the tv, look for the 6 little nobs, look at the ones on the left, they should agjust the red, thrn the top one untill the red is focused back in.
Pioneer Elite Pro 710HD Rear-Projection Television
no reset sequence. usually when the protection kicks in without any warning, it's the convergence ICs needing replacement.
Mr Bob
www.imageperfection.com
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
2answers
SD-643HD5 64 in. Rear Projection TV
I had the same problem which was caused by a bad solder connection on my Green CRT driver board. The fix isn't too difficult if you've had some soldering experience.
1) Determine which CRT is going out (Reg, Green, or Blue). Looking at your convergence adjustment screen will help.
2) Unplug TV
3) Remove the front panel
4) Locate the driver board attached to bottom of the bad CRT.
5) Locate the two large heatsinks on the driver board, each has a transistor attached to it.
6) Touch-up the three solder connections on each transistor. Adding some new solder helps.
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
