Recently purchased a Sungale Diginal Photo Album from QVC. I plugged the AC adapter in and followed the instructions in the manual to download photos while the AC adapter was plugged in. I left the adapter plugged in and after a while noticed the red light was no longer on so I unplugged it. When I tried to turn the DPA on to view the photos it would not come on until I plugged back into the AC adapter. I do not see anywhere in the manual that tells me how long the DPA needs to charge before you use it without the adapter nor how long you can use it without the adapter. Can you answer this, please?
SOURCE: my sansa won't turn on!!
I can help you with the "bad track." That error message will come up once in a while. The files in your computr are not corrupted or anything: only the sansa's files are. Taking those bad tracks off won't help, you have to format it or something (I'm sorry, I forget excatly what it is!) but if you right-click on the sansa in My Computer theres OPEN, EXPLORE, and then FORMAT. This will wipe everything off of the mp3 player, but the problem you have with the bad tracks should be fixed. Just upload them again. I am really sorry I can't tell you how to fix your other problem, I'm having a similar problem with mine right now (I formatted it, then it stopped responding to my computer and won't show any image on the screen, just white letters).
SOURCE: downloading songs from computer to mp3 player
If you songs are downloaded in a folder for example my music,,,after you connect your device (mp3) into the usb port in your computer or laptop you wil get a notification of new device being installed, you follow directions on screen. Once the mp3 is intalled the you can goto my computer and you will see an icon on the screen for it. Click on it open it up, minimize the screen, no go to my music folder , open it up, minimize it too, now you have the two floders open, just drad the music from the my music folder to the mp3 folder icon and there you go,, i have found these to be the easiest way to do it. please advice.
SOURCE: sansa clip player wont turn on
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
SOURCE: Sansa Clip won't charge
Here's the thing, technically it doesn't need to be turned on because it's supposed to turn on by itself.
I've had a problem sort of like that. It might be the plug, but it also might be the computer. I'd either suggest try plugging it into another computer or getting a new plug.
SOURCE: battery fully charged,but will not turn on when
The battery wire inside may have broken off...its a common problem in sansa clip...if you are comfortable opening it up,you need to solder the wire into place correctly...
