LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
Posted on Dec 14, 2008
LaCie 500GB external will not show up on mac desktop. Blue light on, whirrs as if working but no icon on desktop (not mounted)
  • Anonymous Jan 15, 2009
    I am having the same issue but my light on the front is yellow. I went to Disk Utility and it does not show up on the left side column.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 16, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
808
Points
Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running Leopard, not positive if the same applies to Tiger. I hope this helps you
My lacie external hard drive doesn't show up on my desktop the light just flicker
When it eventually will, check the disk (all terms may vary, depending of your version of Windows) :
Right-click the icon of the disk, then click "properties".
In the "Properties" window, select the "Tools" tab, and click "Check now". Check both checkboxes, and run.
This should fix the access problems on your drive.
2answers
LACie disks are mounted on the desktop
http://www.pricespider.com/products/454765/LaCie-D2-301110U.html
This link has product reviews and problems others have had with it. It may be worth checking out.
Let me know how it goes,
Thanks
yalmer
1helpful
The icon for my lacie exyernal hard does not show
Here's two suggestions. (If your using Mac OS X 10.x)
Make sure external hard drives are to be shown by clicking "Finder" in the menu bar then "Preferences" and under the "Sidebar" section selecting "External Disks".
Also check that the hard drive is mounting by opening "Disk Utility" by first opening the "Applications" folder then the "Utilities" folder and double clicking "Disk Utility" and in the left sidebar checking to see if your external hard drive is listed as one of the mounted drives. Hope this helps, don't forget to comment/vote if this helped. Thank you.
LaCie icon won't show up on my mac desktop
1. A. Yes.
2. A No.
3. A. Replace the LaCie
1helpful
2answers
LaCie HD won't show up on Mac desktop, quit showing up yesterday
Hello! Had the same problem - go onto the Lacie official website. Select whatever type of drive that it is you have, and simply go onto the software update page. I literally downloaded the desktop manager (I own the Sam Hecht Little Disk) and it appeared! Good luck
2helpful
3answers
Drive not showing up on my desktop
i'm not sure i can solve this problem--which started for me tonight as well with my lacie d2 quadra 500 gb--but i can share a possible explanation i've found online: apparently, they have lots of problems with their power supplies. see if the power adapter (the black brick) is making a hissing sound, or if there is a ticking sound coming from the drive itself. i have both these sounds. i am hoping all my data is safe and that my i.t dept. will be able to fix it with a new power supply on monday.
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Lacie d2 external drive
you may need to get a new driver for that lacie from their website..
support downloads, model o/s
Mounting an external hard drive onto my I Mac
Hi, I have just checked the LACIE website, So Google LACIE, click the second result [Lacie's own site] you will get a page up with a choice box, select Australia/go click the desktop HDD. click the 500Gb usb, this will give you a page with a support and a download link. click download, here you will find a manual and drivers. Goodluck mistyman
Top LaCie Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Steve Sweetleaf
Steve Sweetleaf
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
