20 Most Recent LaCie Ethernet Disk (300788) 1000 GB Network Hard Drive Questions & Answers
Try reseting the hard drive - cycle the power or unplug it for a minute then plug it back in.
LaCie Ethernet... | Answered on Oct 28, 2010
Mine used to do that too.
It's working much better since I repaired the power supply.
The power supply shipped with the disk is really bad and dies in less than one year. I had to replace mine 3 times !
I'm now using a power supply I repaired by replacing the 5 capacities and it's working fine.
I hope that will help.
LaCie Ethernet... | Answered on Oct 01, 2010
Have you installed the lacie network assistant?
LaCie Ethernet... | Answered on Sep 17, 2010
go there (http://www.lacie.com/intl/support/faq/faq.htm?faqid=10708) follow the instruction... more than easy... note : drive must be off before pressing the button for ten sec.
LaCie Ethernet... | Answered on Jul 09, 2010
What says that?
I don't have enough info.
Check your connections, make sure everything is powered correctly. And make sure you installed the software that came with it.
LaCie Ethernet... | Answered on Apr 03, 2010
I'll have to look into it a little more but off the top of my head I would say that the nic may be going bad or some other component of the etherdisk. You can try opening it up and putting the hard drive into an enclosure and connecting it to a pc via usb to get the data, you can also then share the usb drive and use it over the network, however removing the hard drive may void any warranty you may have. If the hard drive is in fact bad then you should be able to replace it and then continue to use the device. I'll get back to you when I get more info about the device.
LaCie Ethernet... | Answered on May 25, 2009
I had the same problem in Vista but it spontaneously resolved itself after some time, but as a temporary solution you can just map to it. Figure out it's IP address and then go to: Start->right click on Network->Map Network Drive...->fill in the Folder field (i.e. \\192.168.1.2 ) and presto you should see the login screen (admin/admin by default). It's not the best but works well enough. Hope that helps.
LaCie Ethernet... | Answered on Jul 13, 2008
default user administrator default password admin
LaCie Ethernet... | Answered on Nov 15, 2006
Just an idea. When you set pass words or any important information write all information in a note book and keep it in a drawer someplace where you will not lose it. When things change write the new ones down and cross out the old ones. I save a lot of head aches that way.
LaCie Computers... | Answered on Jan 22, 2019
Pushing in the paperclip should unlock it, but if still jammed, may have to wreck drive by pulling off front of drive drawer thing. Maybe try putty knife to push cd down some of that's holding it from opening.
Replace perhaps, but repair is most difficult. The electronics are miniature and it takes special tools to do repairs.
LaCie Computers... | Answered on Jan 02, 2019
Two ways this can go. If you are talking about the entire hard drive pulling it out and plugging the whole drive into another pc. Then you're fine
If you are talking about disassembling the hard drive and moving the disks inside. This is not something you can do.
This is what you will need.
1) a certified clean room surgical grade
2) tape
3) A matching drive/ hd board down to revision number
4) presision screw tools.
5) patience.
Or you will need to contact a professional data recover company.
LaCie Computers... | Answered on Dec 29, 2018
LaCie Ethernet Disk (300788) 1000 GB Network Hard Drive Logo
20 questions posted
Top LaCie Computers & Internet Experts
Marvin
Marvin
Alun Cox
Joaquim Martins
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • LaCie Computers & Internet
Most Popular Question
lost password user lacie network space
  • Computers & Internet
