Some buttons are working but the START button is not working
SOURCE: our GE countertop microwave key pad does not work.
HI. Kindly, unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the error continues, the touch pad should be replaced asap.
SOURCE: I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer
SOURCE: GE model JVM2070SK02 touch pad not working
Most people, and GE will tell you these are not repairable and you must replace the whole unit for $300 - 500. I can fix them. If you are interested, let me know. [email protected] I can only fix the touchpad not working and it must not be physically damaged. You must be able to take out the control panel and send it to me. It is easy (3 screws and electrical connectors).
The only way possible to see if the touch
pads are working is to test the voltage of the control pads when it contacts.
The input of the Microprocessor should be checked for the pad control impulse
to come in. If there is no trigger voltage to the mP this can be the control
pad problem.
The mP must be checked for the working voltage and also the frequency
oscillation at the crystal leads. If so the mP is working with a suspected
control pads which are not able to set the program or timing.
There is no way but to remove the sticker pad and replace, One difficult way to
have a chance is to remove the carbon sticker pads and check continuity , You
can use a carbon pen to line the tracks so that the multi-meter reads a
continuity. With this you can have a temporary fix
Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
If only the start button is inactive but you are able to set timing then then the start button pad must be worn out.
