Goldstar MV-1526 1000 Watts Microwave Oven
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with Goldstar MV-1526 1000 Watts Microwave Oven?
Troubleshooting and Support
Solved Problems for Goldstar MV-1526 1000 Watts Microwave Oven RSS Feed Post a New Problem
Gold Star Microwave- model MV 1500MG
The door glass is stained brown - how do I clean it-It is in between the panes
1 Solution
Emerson Model MW8627W does not heat after...
This Sunday, I heard a "pop" from my microwave. I knew instinctively that it was the fuse. The bad fuse was...
STAFF 1 Solution
Door Latch
Well so my wife broke the latch to the microwave. I tried glueing but that didn't work. I have a Gold Star MV1501W and I...
1 Solution
Golstar MV-1501V Microwave
The door has turned brown in the inside caused by it appears the steam from cooking even though the fans are always on....
1 Solution
filters
how can you chage so it vents inside through filters and not inside? also where can i get new filters
1 Solution
Goldstar MV1526W won't run
Fan turns on and lights come on, but the turntable will not turn and it will not cook. Is it the magnetron or a board...
1 Solution
Goldstar MV1526B
Went to change the night light for the first time, and when I turned the bulb it separated from the "screw-...
1 Solution
Unsolved Support Problems
Unsolved Problems for Goldstar MV-1526 1000 Watts Microwave Oven RSS Feed Post a New Problem
do i have to take the microwave off the...
replace fuse: do I need to take the appliance off the wall to find the fuse?
Post a Solution
broken microwave
I opened the door and it burnt the electronic panel on the inside and dosen't work anymore. Is it fried or can it be...
Post a Solution
Dorr Glass
window glass in the micro door slides down when in use
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Microwave TypeOver-the-Range
Cooking Power1000 Watts
Capacity1.5 cu. ft.
Dimensions
Exterior Depth15.58 in.
Exterior Height16.44 in.
Exterior Width29.94 in.
Sponsored Links
Loading problems.
Top Microwave Oven Experts
Microwav
260 solutions
Microwave Ovens
Ask Me
Guru
sedonix
3 solutions
TV and Video, Home Audio, Calculators, Microwave Ovens,...
Ask Me
Guru
sharcnet
2 solutions
TV and Video, Cameras and Photography, Personal Audio...
Ask Me
Guru
Repair Service
Find Microwave Oven Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
