LG LTM9000 900 Watts Microwave Oven
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with LG LTM9000 900 Watts Microwave Oven?
Troubleshooting and Support
Solved Problems for LG LTM9000 900 Watts Microwave Oven RSS Feed Post a New Problem
Toaster Side wont 'start'
I have an LG Model LTM9000 and all the buttons work on the toaster side except the 'start' button. It won't heat. Any...
1 Solution
Emerson Mwg9111sl microwave blows 20 amp...
Less than 1 year old, turned on one day loud transformer noise then blowed 20 amp internal ceramic fuse. I know air...
1 Solution
Toaster Failure
After 3 yrs, the toaster will not heat.  Is this a heater element problem?  Easy to fix?  Or should I...
1 Solution
LG LTM9000 doesn't power on
It was working fine for 2 months. After that, suddenly was turned off and never more worked. I took out the ceramic fuse...
1 Solution
LG make Combimode microwave oven not...
Dear Sir, I possess LG Make Combimode Microwave oven purchased through Associate Electronics, Coimbatore,...
2 Solutions
danby microwave m # 1153
no heat,light or turntable movement all functions on pad seem to work, when door is opened turntable works.
1 Solution
Unsolved Support Problems
Unsolved Problems for LG LTM9000 900 Watts Microwave Oven RSS Feed Post a New Problem
microwave oven not heating
My microwave oven in working but does not generate heat to cook food, can you give reason for the same.
Post a Solution
PLATE DOES NOT TURN
THE ROTATING WHEELS ARE IN PLACE, THE GLASS PLATE IS IN THE GROVES ON THE PLASTIC CENTER PIECE. I BELIVE THAT THERE IS...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Microwave TypeCountertop
Cooking Power900 Watts
Capacity0.9 cu. ft.
Convection CookWithout Convection Cook
Power Levels10
Other Features
TurntableYes
Turntable Diameter (display)12 Inches
Controls TypeElectronic Touch
Dimensions
Exterior Depth16.56 in.
Exterior Height12.19 in.
Exterior Width21.31 in.
Safety Features
Child LockoutYes
LG Contact Information
Main support number1-800-243-0000
Email supportcustomerservice@lge.com
Sponsored Links
Loading problems.
Top Microwave Oven Experts
Microwav
260 solutions
Microwave Ovens
Ask Me
Guru
wilbur24
3 solutions
Large Appliances, Small Appliances
Ask Me
Wiz
sunligre
1 solutions
Flat Panel Televisions, Personal Audio...
Ask Me
Wiz
Repair Service
Find Microwave Oven Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
