Had cruise control module replaced, but it kicks off when driving
SOURCE: 2005 malibu where is the brake light switch?
There isn't one. This car has a "brake and throttle by wire" system and the brake light switch is inside of that. You have a bad brake position sensor. Figure $240 or so at a dealer.
SOURCE: ABS control module "brake fluid pump" runs constantly.
I do not know anywhere that can repair the module, and yes one from a salvage yard is a good idea.
SOURCE: cruise control quit working today
Check for vaccum hoses attached to the cruise control module in engine compartment. These hose may be try rotted and your loosing vaccum when you activacte cruise control.
SOURCE: brakes lights don't work, only 3rd brake light does.
If your third brake light is working, then we know it is not the brake switch. Get a test light and check to see if you have power at the light socket. If power is present possible bad ground. If no power, check connections inside of the trunk. Also choose a spot just behind the back seat to be sure that power is on the brake light wire, this will check for possible break along wire.
SOURCE: Was driving with cruise control
Will probablly require throttle body. electronis controlled.
