Toll-Free +1-866-231-0111 Brother printer receiving the 'Drum error'? Then, you have to clean the corona wire on the drum unit of your printer immediately to resolve the issue. Brother Printer users often face this common error but before calling the company for an instant tech-support, trying some steps can help to resolve the issue. Have you been facing the issue for quite some time and keep asking yourself How to Fix Brother Printer Drum Error? Then we here have some solutions for you. Follow the given steps and DIY resolving the error and see whether it's gone or not.
Step 1 Fix Brother Printer Error Drum
· Slowly open the lid of the printer and remove the drum unit · Also, remove the toner cartridge assembly · Keep a piece of paper on which the parts can be kept to avoid spilling of the toner
Step 2 Brother Printer Error Drum
·If the error Drum still persists, you have to replace the drum assembly. ·Consider resetting the Drum Counter ·Press the 'Menu' option> click on the 'Machine Info'> now click on 'Reset' ·Press Ok ·Now Press 1 to reset the drum unit counter ·Press Stop or Exit when
Brother Printer Customer Care Number +1-866-231-0111
If the mistake occurs, call for instant assistance at the Brother Printer Customer Care Number +1-866-231-0111. We are a 24 * 7 group of well-qualified and experienced engineers. We are willing to help you with your toughest printing mistake. Our techies strive to provide analyzed responses to all inquiries linked to the client
I've had this problem recently--what you'll need to do is press GO and + at the same time. You'll need to get it just right otherwise you'll end up pausing the machine a ton. That should take you to a list of parts, just scroll to drum kit and press 'Set' to reset it.
If toner save is turned on all will be light, you need to check in user settings, also remove the drum and wipe the narrow glass that is above where the drum sits inside.
Open the front door, pull the toner and drum assembly straight out towards you, press the blue lever on the left to remove the toner cartridge and install it in the new drum assembly and re-install in machine. While the front door is open press the clear button, display will ask "new drum?" answer yes, all done...
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
