I dropped my treo phone a while back and now my keys are stuck and I cant even use it. Is there any way to fix this problem??
Sure. This involves taking the phone apart. Fortunately, it isn't difficult. Go to "mytreo.net, and find the BUZZ FIX. It will give you instructions with photos of how to open your 600 and perform the BUZZ FIX. Do that while you have the phone open. You will disconnect the battery in that process. Carefully lift the board that the battery is mounted on and this will expose the KEYPAD. Remove it, clean the keypad, and the pressure contacts below it -- carefully with a Q-tip and a little water and perhaps a little alcohol. Put the keypad back in place. Put the board back in place. Reconnect the battery after performing the BUZZ FIX (you may as well do it while you have the unit apart because you will have the buzz sooner or later). Put the case back together. Tighten the screws. Turn the unit on and make a call. If it doesn't work then you are in trouble.
How long have you had the 650? Palm offers a 12 month warranty with all of their treo's. It's very possible that Sprint will exchange this product at no charge. I have found the 650 to be the most unstable treo ever made. I had replaced 13 of them before finally switching to blackberry. That does not mean you will suffer the same issues. I would use the palm/sprint warranty if still available.
James
