Cars & Trucks Logo
David Selby Posted on Jun 26, 2012
1987 Cadillac 3rd gear band adjustment
Band adjustment
A
Anonymous
That's a transaxle correct? 4T60E?
There is no band adjustment
If a band on any trans wore enough
to need adjustment,then the trans would
need an overhaul
2helpful
Since i changed my trans fluid now 3rd gear slips engaging, does the band need adjustment? was ok before. pan gasket was leaking and I changed the filter.
if the band needs adjusting then it would be doing it before the oil change
possible that while you were doing something, the vacuum line or the vacuum actuator was damaged or wires to the 3rd ratio servo/ solenoid were damaged
run the fault codes to find out the fault area
Band adjustment, how many turns out on 1987 300zx
Transmission Bands are adjusted when you rebuild a trans
They do not wear enough to need adjustment
Two things happen
If you turn the screw the wrong way, parts fall inside the trans
& you can't get it back together
Next-- if you need to adjust the band or bands, it is time for a rebuild, as many many parts are worn, long before the slightest band wear.
Why is it taking long time to shift from 2nd to 3rd gear
have a pressure test done on the gear box to determine if the fault is mechanical. Have the bands and clutch packs adjusted . RTUN fault codes to check TCM problems.
2answers
I got a 1987 chevy s10 pick up truck 2 wheel drive v6 2.8l my transmission is not passing 1st gear ?do you know if the kick cable or tv cable needs to be adjusted .
Just about all you can do is, with the engine off, from under the hood open the throttle all the way and check if the TV cable is tight. And check the fluid level, smell if its burnt or look if its brown.
Other causes could be,
Sticky governor
Sticking shift valve
Worn bands
Many years ago my mom's first 4 speed automatic was a 84 S10 2.8 2wd. She did not know it was a 4 speed and the indicator was broke so she counted the clicks to find drive. She was driving in the hills in over drive and all the downshifting was too much for it (should have driven in hills in 3rd gear). After that the transmission would not shift out of second gear.
1helpful
87 cutlass no reverse
foward and no reverse.In order for the reverse to happen there is a transmission brake assemble,the transmission band holds the brake assembly thus allowing fluid to be driven according to gear selection, when no reverse happens there is a malfunction of mechanical or hydraulic part, Depending on the condition you can adjust the kick down or adjust the band. A general procedure for automatic transmission band adjustment involves tightening the band adjusting screw to a given torque sequence, back off the adjusting screw from turning while torque-tightening the adjustment screw about a 1/4 turn and lock down the lock nut,and recheck to see if reverse has been restored.
2answers
I have a 1990 chevy 4x4 automatic when it is going to shift to third it just seems to go to nutral oil doesnt smell burnt and is not low what could cause this
you have a broken overdrive drum inside the transmission, the only way to repair it is to overhaul or replace the transmission....sorry
2helpful
2answers
1998 subaru band adjustment for auto transmission.
It is on the left side hard to spot. Look below the heater hoses. Good luck, take your time and have a great day.
2answers
46RH transmission, no second gear.
Does it shift into 3rd at the right speed? If 2nd is just missing, try adjusting the kickdown band. (front band). The adjustment screw is on the outside of the case.
Engine over-revs between 2nd and 3rd gear
they did not install bands right needs to be rebuild bands need to be adjusted
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
