This stacking part is all you need. It is a white plastic bracket that attaches from the rear of the two appliances. And it should have come with instruction too.
The recommended stacking kit for your Frigidaire dryer (LEQ1442ES1) is part number STACKIT2. Further information regarding the stacking kit and directions can be found in the installation instructions listed below. Hope this helps! - Z Frigidaire Manual Search Results
Hello the advice about removing the top of the washer and bolting the dryer to it is exactly what to do.Under the washer top is built in brackets to do that.Every front load Frigidiare washer leave the factory pre-equipped to stack the dryer to it by removing the top and bolting the dryer to it
measure your dryer carefully and check with the dealer where you wish to purchase a machine, regarding
the stacking kit. It may work. They are general standard sized. Don't ry to gerry rig anything or you may have big problems. In your case I recommend using a well known SMALL appliance store that does theri own installations, so they will bring what they may need, but if yours works, they can still use it.Good Luck
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
