I have a Maytag Performa dryer that just stopped in the middle of drying. I reset the circuit breaker, nothing. When the door is open the light comes but not anymore. Any suggestions?? I have a Maytag Performa dryer that just stopped in the middle of drying. I reset the circuit breaker, nothing. When the door is open the light comes but not anymore. Any suggestions??
You can't post conmments that contain an email address.
it is likely the Thermal Fuse, LA 1053 kit for Performa Electric Dryers. You have to open the case, remove the drum, Loose the back panel and remove the Heater element case. The Fusible Thermostat is on mounted on the side of the heating element case.
how long is dryer vent run ? does it go up or out to the side ? Sounds like the dryer vent is clogged. A long run on your vent will also cause this problem with a small amount of lint. Try cleaning out your lint screen on the dryer vent they can get pretty caked up with lint. If you have a long dryer vent run post back the length and direction and I will get you the maximum length for your specific run. You may need a booster fan if it is excessively long or straight up as through the roof.
I am not 100% sure I understand your question but if you need to know how to reassemble your dryer after cleaning it out,.use this link .. It has exploed views and parts lists .. http://www.pcappliancerepair.com/model-display.php
If my reply does not answer your question, please clarify your concern and I will assist you.
Regards,
Rick
hi .thanks for the question .no the element does not go bad a little at a time. but the venting gets clogged up a little at a time . remove the venting and clean to the outside wall . also if the dryer is noisy you could have a blower problem. if the dryer is noisy .but check the venting thanks the appliance doc
You are always better off using steel on these kinds of conversions and do not worry about how hot it gets,..Aluminum will get hot too. Steel is more rigid and less likely to dimple in while installing or hooking up the external vent system... Hope this helps..
