First you will need the SATA driver already saved on a memory stick. Now go into the BIOS and change the boot order: put the cd first then the hard disk second, save the new setting and reboot. Put the XP install and reboot again, the install will start. When instructed to input extra drivers plug in the memory stick and point to it. After that don't forget to install all the other drivers from here.
http://toshibatips.blogspot.com/2009/01/satellite-pro-l300-notebook-windows-xp.html
It seems as if you have downloaded a spyware program such as a wallpaper which has caused you to have a fake antivirus 2009 running. Make an Ultimate Boot CD and run every AV tool and spyware/malware that was on the CD. After running all the tools install your XP SP2 CD to repair the installation Download and run hijack this to see if still have the virus lurking on the computer.
Is it giving you any error or out of the ordinary "beeping" as it is booting?
Usually the BIOS screen comes up if it cannot find an acceptable boot device.
Can you boot from an XP cd?
Can you boot into set up mode.. usually by pressing F1 or F2 on most computers. It should tell you just before the BIOS screen comes up. Enter into "set up" and make sure your boot order is correct.
You might want to reseat your RAM.
Check to see if the hard drive is coming on.
Most toshiba will boot if you press F12 and a boot screen will appear . the bios is most of the time acessed through F1 or F2 try that and let me know what happens
It can have boot virus and when booting it finds your antivirus soft and if cant stop antivirus then calls "crash" screens, also sometimes real crashes heppened vith driver incompatible or incorrect parameter stored. If you have any LIVE Windows CD or linux boot from it anc check for viruses, also make disk check with disk utility. If not corrected windows must be reinstalled. If you havent try try "last good known configuration " from bootup screen, to call boot press F8.
