Simple fix. Just remove the power cord, remove the battery, then remove the screws from the cover that houses the hard drive on the bottom of the laptop. Most times the cover will have the icon of 3 or 4 circular discs on it to represent the hard drive. Once you have the cover removed, there might be screws that hold the caddy inside the bay, if so remove them then you can lift the drive and caddy out of the bay. The drive might be inside of a caddy with screws holding it to the caddy. Remove the screws from the caddy and then you can remove the drive.
Notice what type of interface (IDE or SATA) your drive is and replace it with the same type of interface drive. IDE Drives have about 20 or so metal pins or prongs that stick out. SATA drives have two small plastic looking pieces that connect it to the interface inside the bay.
Hard drive is bad or is going to fail soon.
Solution
Backup your information and contact the maunufacturer of the computer or the hard drive for replacement or additional help.
In some very rare cases the S.M.A.R.T. implementation on your computer may have issues of its own and may need to be patched before replacing the hard drive.
If I am receiving the S.M.A.R.T. error, is it ok if I continue to use my hard drive and do not replace it?
As stated above, S.M.A.R.T. is designed to detect upcoming failures in the hard drive.
While it is possible that the hard drive may not fail for several months, it is still inevitable that the hard drive will fail.
It is ok to continue to use the hard drive, however, we highly recommend that if you are still under warranty that you consider getting the drive replaced before your warranty runs out.
hope this helps
