Virgin Pulse VP-MPF-1000 (256 MB) MP3 Player Logo
Posted on May 17, 2012
I need driver software for virgin mpf-1000
I need the driver software compatible with my windows vista
1 Related Answer
Anonymous
  • Posted on Jan 09, 2008
SOURCE: My virgin pulse need driver
I can't find my software for my Virgin MPF 1000 where can I get it?
3helpful
Microsoft LifeCam VX-1000 Webcam send me win2000 driver
Compatibility and Localization
Interface
Full-speed USB compatible with the USB 2.0 specification
Operating Systems
Microsoft Windows® 7, Windows Vista®, and Windows XP with Service Pack 2 (excluding Windows XP 64-bit)
Top-line System Requirements
Requires a PC that meets the requirements for and has installed one of these operating systems: • Microsoft Windows 7, Windows Vista, or Windows XP with Service Pack 2 (excluding Windows XP 64-bit)
sorry win 2000 no compatible
techbelkin
tip
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
729dcf7.jpg.
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
on Jan 24, 2010 • Computers & Internet
Vista compatibility
no it is not because  compaq c3 1000 windows vista  is not good as windows 98 or the new windows 7
Unable to install scanner
Cant find such a scanner, are you sure of the model "performance", If it is not Vista compatable, ie if Epson have not released a Vista driver, then it is not going to work with Vista.
See Epson web and download driver if available, if not change scanner or operating system or purchase software
Check your Epson product CD to see if it already contains Windows Vista drivers. If the CD indicates support for Windows Vista, follow the instructions that came with your Epson product to install your driver and other software.
If your Epson CD does not indicate support for Windows Vista, DO NOT INSERT YOUR EPSON PRODUCT SOFTWARE CD IN YOUR WINDOWS VISTA COMPUTER because the setup program is not compatible with Windows Vista. Instructions for installing additional software from your CD may be available with your driver download.
Note: If you already have ArcSoft PhotoImpression™ 5 installed on your Windows Vista computer, you may need to install a "patch" program. Go to the ArcSoft website to download and install the patch.
Products that are not Vista compatable are not capatable with Vista, who would figure hey!!
H.E.L.P!!!!!!!!!!!! PUHLEZE!!!!!
I had the same problem with mine. All you have to do is search these keywords: Virgin, MPF-1000, Driver, Download
When you search those keywords you should have quite a few options to download the drivers needed. Anyway, here are a few links to the software and/or drivers needed for you to be able to get your Virgin Pulse MPF-1000 working.
http://www.soft32.com/download_172979.html
http://www.versiontracker.com/dyn/moreinfo/win/39151
http://wareseeker.com/Utilities/virgin-mpf-1000-2.6.0.28.zip/1fbd18a12
http://pcdrivers.es/vp-mpf-1000-driver/download-2785.html (This download website is in Spanish for those of you that can only read/speak in Spanish)
http://www.drivers-software-download.org/virgin-mpf-1000-26028/
That will be all you need to do. Once you have installed the driver, plug the MP3 into the USB. Once you plug it in the autoplay should come up and just go from there. Please let me know if this solves your problem.
Thank You & God Bless,
MadHatter25
Is ultimate solitaire 1000 compatable with windows vista?
It is designed for Windows XP, running DirectX 9.
You can try running Backwards Compatibility that Windows Vista provides backwards compatability with win32 operating systems.
Only warning is that not all programs run efficiently and there might be bugs because of the different Operating Systems and the OS software was built for.
48helpful
8answers
Microsoft Lifecam 1.1
i cant install my microsoft lifecam1.1 webcam software on my vista pc
1helpful
Vista Cannot Locate Scanner Driver
windows vista has compatibility problems with many device softwares and drivers, u have to get the software that's windows vista compatible, or u can log onto the visioneer site http://www.visioneer.com/ and download your device's software that's compatible with windows vista
How can i download the software without the software
how can i download driver of Virgin Pulse VP-MPF-1000 MP3
2helpful
2answers
Top Virgin Pulse Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Virgin Pulse Audio Player and Recorder Expert? Answer questions, earn points and help others
