Thats it, Let me know do you have any experience of TV repair? because your TV has hardware problem in sound processing board and it requires to apart TV and test / check voltage on it. If voltages are found correct, you may need to replace board. I will provide you more info like what voltage on what board will be tested / checked upon your reply of TV repair experience question.
How did this happen????? If water is dripping from the tv, do NOT switch the tv on else this may be dangerous and damge the tv. How bad is the water damage? Is it dripping from inside?
There is a component(s) in the video processor path, or in the screen address matrix that has become thermo sensitive. This can be service by someone who is familiar with and has the tools and set-up to service your model of set.
I would suggest to call Sony service to arrange to take it in for an estimate. Because of the complexity of servicing this set, they may give an estimate to exchange the defective board(s).
The cost of servicing your set when out of warranty will not be cheap.
Changing this requires a change of the tuner. There is nothing inside the set that can make this change. There are external systems that can do this, but they are expensive (multiple $100s).
Bottom line is that this would require a change in the internals of the set.
Hope this helps.
I have no experience so I guess I need to call a technician?
