Uniden Cordless Phone Logo
Posted on Nov 19, 2008
Clicking noise both parties can hear a clicking noise that gets louder during the conversation.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Nov 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
892
Points
7
I had the same problem and Threw them away because it wasn't worth it to me to pay to ship them back, for them to fix them when they cost me 10.00 after rebate & it was more for shipping. sometimes the sell you refurb. and say they are new, I bought a new 1 and when I called & gave them the ser.# they told me it was a refurb. I won't buy another Uniden Cordless Phone.
Go with Panasonic phones.
My corolla altis 2002 model makes noise during idling and when trying to accelerate noise comes more louder and it doesnt have power but i changed the timing kit and the valves,it also shows the engi
I'm pretty good with noises, but to answer your question, you're going to have to describe the noise itself. For example, at idle you hear a clicking, chattering, squeaking or rattle. If you can also let us know where the "noise" is coming from (engine, trans, drive axle) that would also be helpful. Try to be as descriptive as possible, so somebody can help you out. Most people have experienced the same issues and can help if given a better description.
Loud clicking during hard accelerating
When you say the work clicking I think of CV axles going bad. But you would mostly hear this when turning the car. A cracked exhaust manifold will make a ticking noise when the cylinder fires where the crack or leak is. It will be louder when cold as the metal will shrink when colder then expand and close in the crack when hot. If the power really is cutting out when you hear the clicking then it could be an arcing plug wire or plug but this would throw a trouble code for a misfire.
Noise in left front wheel
Grinding noise, growling noise, thumping noise? Something else? If it's a grinding noise, more than likely it is during stops. In this case it is probably metal on metal in the brake pads. If it is a growling it can be in the wheel bearing or CV shaft which usually gets louder with turning or banking. Is it is a thumping can be from a tire issue, a strut, a sway bar link banging around etc. Need to clarify the noise and how you are hearing it.
What can I change on my phone so I can hear when some one calling me
there is an in call volume on the right side of your phone,press it up during a call and the volume of your phone will be louder for you to hear the other party.hope it helped you in anyway..
3helpful
Every 20 minutes, my freezer would make a crackling like noise. What does this mean and how can I fix this?
Refrigerators are not the most complicated appliance in the house, but it still takes a lot of parts working together perfectly to keep your food cold. If one of those parts breaks down, or begins to, you may start to hear new noises from your refrigerator. Fridges make some noise during regular operation, but if it suddenly gets louder or makes a different noise, it is a good sign that something is wrong.
Freezer Fan
Freezers can be located on either side of the refrigerator, or may be at the top or the bottom of the unit. If you hear a noise coming from the area in which the freezer is located, you should open the freezer and see if the noise gets louder. Any squealing sounds coming from this area indicate a broken freezer fan. These units are not designed to be repaired, and eventually one making a loud noise will break and need replacement.
Condenser Fan
All motors typically require a fan in order to maintain a safe operating temperature. Like the fan in the freezer, the fan that runs on the condenser can also break down and create a similar squealing noise. The location of the fan noise is what differentiates the freezer and condenser fan problems. If you hear a fan noise coming from the lower part of the fridge at the rear, it is likely the condenser fan causing the problem.
Action to do
Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
Thanks for using FixYa.
Good day ! : )
2helpful
Very noisy when on spin. The machine seem to be balanced however the noise on spn is like a jet taking off. it gets louder as the spinning speed increases.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
New washer, Maytag title, but RCA unit--knocks and clanks
Thank you for your complaint. It will be forwarded.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
8helpful
2answers
Nokia N72
to record voice memos, press the menu button, and select OFFICE->RECORDER. To record a conversation, choose RECORDER during a voice call. Both parties will hear a beep every 5 seconds while call is being recorded.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
