When i download music onto it via raphsody it doenst show the results in the player but will show up if you connect to raphsody. Is there a solution for this? Thanks ahead of time Michele
be sure that you have already saved a list of song on your playlist. and for the pdf also make sure that there was a file that save on that location...
Sync all the songs you want onto the raga via 'songbird'.
Stay connected, then go to windows explorer, identify your device. Then in 'Music', make folders for your playlists. Manually transfer (drop and drag) your songs to the required folder/playlist.
When using the raga use the 'folder' option. Works as playlists.
grayza
Easily, you will have to go into the itunes settings and configure it to manually transfer/sync songs and playlists. After that you can move files from your computer directly onto your ipod via drag and drop or you can create a playlist and place the playlist on your ipod in itunes via drag and drop.
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB". 2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode - Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list - Select the Sync tab and click "Sync settings" - Check "Synchronize device automatically" - Set "View" to "All Playlists" - Place a check next to the playlists they want to transfer to device - Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
well there are some sites where download songs for free. when you download the songs go to my computer click the drive your usb is in (as soon as you do that sometimes you might also have to do that) then you see your files cut and paste the song anywhere there and then take out the usb plug your head phones and find the song you out in.
Yes, but you also need to load the ZEN software onto her computer so that you can add music to the player. You can load the playlist several ways, using Yahoo music, Windows Media Player, or using the Zen Media Explorer.
Create your playlist with winamp and then copy it over with the songs listed in the playlist. You can make as many playlists as you like and they will show up under "playlist" on the screen
