After power outage icemaker would no longer work, but water at door sispencer
Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out. If it is not operating properly it should at least hum and vibrate. If that does not occur your problem lies elsewhere. As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: Icemaker is not working, but water dispencer is OK
Hi...
Try to check this
Good luck !!
Regards
PCmania
SOURCE: No water to icemaker. Water in door works well.
the water that enters the ice maker is controled by a thing called a solenoid valve (electricaly operated) the" water in door system" is a manual operated valve.. typicaly when the ejector rolls around to put the ice in the tray the solenoid opens lets water in then closes could be solenoid / wireing or controler
good luck
SOURCE: kenmore 56541 side by side icemaker nor making ice
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Testimonial: "good advice, hard to determine answer ,working now but can not turn off even if bar raised to stop"
SOURCE: fridge will not make ice
This happens on my Sub Zero. I turn the whole fridge off for 30 seconds and this resets the teeny-weeny "brain" on the ice maker. Simple and can't hurt to try.....
