Televison & Video Logo
Posted on Nov 16, 2008
My dvd player is making a loud humming sound when i load up a dvd. it is the phillips dvp5960
Anonymous
Level 1:
  • Contributor 57 Answers
  • Posted on Nov 16, 2008
Anonymous
Contributor
Level 1:
Answers
57
Questions
0
Helped
20423
Points
88
Does the DVD player still work, even though it's making the humming noise?
The humming noise may just be normal for that machine. Turn your TV up louder .
If the player doesn't work, the drive is broken, and you would have to send it to Phillips if your warranty is still working. If the Player still works, check to see if the disc is warped or cracked, this'll make the drive unstable, and make the noise.
Hope my answer helped :)
2helpful
Loud mechanical noises from my dvd player during loading,advcing,
hi..the reason for the problem is u have
to clean ur dvd lense.u can clean the lense
using the lense cleaner cd.This will be available
outside.once u clean it will work properly without
any noises.
check it out.
thank u..
Just purchased phillips dvp5960 dvd player and i have a region 1 dvd from the states which will not play .the salesperson said this player would play all my region discs,please advise if you can.thank you
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Setup" button on the remote
9. Press "OK" on the remote
Dvp5960 hdmi set up issues
You can disable the digital audio output in the audio tab at the setup menu.
2answers
Can get picture but no sound on Phillips DVP5960 dvd player
How is the sound hooked up? is it through a Receiver or straight to your TV?
Phillips DVD player, No sound
Swap out the red/whites - loud hum means something isn't hooked up right
Make sure a/v cables going OUT from dvp and IN to tv
Help
maybe,but you must have a drivers for that disk installed on your dvd
Download firmware software for philipsDVP5960/05
can i play my hard drive portable using the phillips dvp5960 usb
7helpful
2answers
Philips DVP5960 DVD Player unlock code
1. Turn on the unit
5. Enter 138931
1helpful
2answers
PHILIPS DVP 5960 DVD PLAYER
password of dvd player pohilips 5061
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
