You can see a button on the panel on which, over the top it will we written 123 (not on the button). It will be after zero. (sorry yaar i just forget that is it star or hash). You press that button continuously for nearly to 5 seconds, on the display you can see some number blinking.
This is the first three or two or the first digit of the counter and after that then again it will be start to blink some three or two or one. if the copies are over 999 only you will be getting the second time blinking with some numbers. others wise you will be getting the same numbers blinking.
eg.: if " 3 " blink then 3 is the starting number
if " 31 " is blinking then 31 is the first two digits.
then in the second time if you seen some number like " 5" then 5 is the continuation of the numbers.
simple if first time 3 blink take the three as first number and second screen 325 blinks then take this set of numbers as the continuation of 3.
then your counter is 3325. ok
may be a big confusion, because i had given here a big statement for that simple statement. try this out.
