Toshiba e-Studio163 Copier Logo
Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The density of the copy is light
A new toner cartridge is installed.the toner lamp is not lit.but the quality of copying is low.
Sunil Rathod
Level 2:
Sergeant:
  • Expert 199 Answers
  • Posted on Jul 09, 2009
Sunil Rathod
Expert
Level 2:
Sergeant:
Answers
199
Questions
Helped
93997
Points
627
Printer require cleaning
Why is my copier printing faint
There are a few potential reasons why your copier might be printing faint copies:
  1. Low toner levels: If the toner in your copier is running low, the copies it produces may appear faint or light. To fix this issue, you will need to replace the toner cartridge.
  2. Dirty or clogged nozzles: If the nozzles on your copier's print head are dirty or clogged, they may not be able to produce a full, even layer of toner on the page. To fix this issue, you can try cleaning the nozzles or running a nozzle check to see if any are clogged.
  3. Wear and tear on the print head: If the print head on your copier is worn or damaged, it may not be able to produce copies with the same intensity as a new or well-maintained print head. In this case, you may need to replace the print head to fix the issue.
  4. Incorrect print settings: If the print settings on your copier are set to a low quality or low density setting, the copies it produces may appear faint. To fix this issue, you will need to adjust the print settings to a higher quality or density setting.
If none of these steps resolve the issue, it is possible that there is a malfunction or defect with the copier that will need to be addressed by a professional. In this case, you may want to consider contacting the manufacturer or a customer service representative for further assistance.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Printer is printing to light for my needs...has a new toner
Verify the toner cartridge.Open the glass platen cover and make a copy,not used an original,if the cpy is a full black papier thr toner density is OK,Clean the polygon unit glass.Enter in program and perform a test page.
Even after replacing the toner cartridge the toner light remains on and the copier will not operate. I have tried agitating the cartridge with no effect. Occasionally on switching on it will operate for a...
Hi Paul
Please answer me a few questions and Ill look into your issue when I get some time later today
Are you using Sharp original toner or after market?
Is the light the "billard ball" one and is it on solid or blinking
Is the drum light on also?
What is the page count on this machine
"clear, density select, clear, density select, dilpay blinks 00 then use arrows for up, zoom for down, to put in 22, press copy then arrow in 05, press copy.. result will be 3x 2 digits repeaed, clear to exit to start of service mode
what is the drum count?, same as above but 12 instead of 05 for second lot of entry
TRy doing clear density, clear density, then 10 copy, can you hear toner motor turning for 30secs?
Dont play in service mode you can damage machine if wrong stuff is put in;)
(clear then clear again to exit all the way out of service mode)
Please post back results/answers
Cheers
Soulvisitor
Installed a new cartridge and copies are bad. Lots of black on copies. Cannot figure out how to change density of copies.
Is it the density or is the problem the transfer roller.....If its the density go into the menus and select print quality and scroll down to the density and lower the setting. If its the transfer roller, you'll need a new one. Make sure the plastic is all removed from the toner...it sounds like you might have left the plastic strip on the toner.
3helpful
2answers
HP Laserjet 3055 All-in-one. Printing and copying too light despite brand new HP toner cartridge. On the computer, "Print Quality - print density set to highest number (5) for darkest. Also tried...
New cartridge means that the transfer corona is probably going out (or the controller board is sending wrong voltage) because it charges the paper to pull the toner off of the EP drum. This might be replaceable but you have to check with HP about buying one. I did not find them for sale on line but some models have them for about $25.
CC and drum Icon will not go out after changing toner cartridge
This Machine needs a copy cartridge. Replacing the toner will not clear it. The copy cartridge is the drum unit which is why the drum light is on. With the new copy cartridge a chip on the cartridge will reset the counter and clear the "CC" and the drum light. If you cant find this I can send you one. I believe on this model it is user replaceable.
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
