SOURCE: Samsung 101cm lcd Mounting??
Yes they are the mounting holes but I would not trust a universal mount to hold an expensive TV set on a wall.
SOURCE: no screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
SOURCE: the backpanel won't come off why? the screws are out
I always miss a screw on LCD Tvs ,they hide screws everywhere. Sometimes they cover a screw with a thin plastic disk so you can't see the screw. Also on some TVs the PC connector has 2 tiny bolts that need to come off. Check around where all your cables go for tiny screws. Also if you still have the pedestal on sometimes they hide screws underneath. once you're sure you have all the screws out gently start pulling/shaking out from the bottom of cover.This usually works for TV 32" and over. Tiny LCD covers are snapped on kinda like how a remote control is put together. You might need a small thin bladed screwdriver to wedge between and gently move and twist when you get near the snap locks.Hope this helps.
Rustym62
http://www.the-tv-dude.typepad.com
SOURCE: sony lcd projection tv in self diagnosis mode. 4 red flashes
This is a fan error take the back off the set and see if the fan is turning.
Did you manage to find a solution to this as I have the inentical issue and I'm starting to pull my hair out? Thanks.
