Disassembled to clean, assembled, but won't start. Power light on.
SOURCE: Toshiba Satellite A215-S4757 blue screen of death
Hello my friend,
Try to check the fan of your CPU if that is properly connected and properly functioning. Usually if the it overheats then meaning the issue is the cooling part of the CPU. Also the memory try to check if it is supported with your new CPU installed.
Hope this solution will help you solve the problem. If you ned more assistance just reply to this post.
Thank you and Godbless.
Jonas
SOURCE: Toshiba Satellite A215-S5818 boot then it goes off
is there anywhere were i can obtain a free data recovery program?
SOURCE: my HP pavilion dv4-2145dx won't
Motherboard is defective & needs to be replaced with a new one.
You can find a replacement motherboard by searching on e-bay.com with the motherboard's model number. This could be found under the RAM.
