Broderbund PrintShop Pro Publisher Deluxe 20 for PC Logo
Posted on Apr 10, 2012
Printshop 3.0 prints incorrectly
When working on a project the layout is correct in landscape but when I print preview the document shows as portrait I want it to print exactly the way it shows in the project.
2 Related Answers
Keep Tryin
  • 4 Answers
  • Posted on Apr 18, 2011
SOURCE: I am having a problem
Make sure your printer and printer settings in the program are also set for envelopes
willem52
Willem.
  • 359 Answers
  • Posted on Sep 04, 2011
SOURCE: A couple of problems: 1.
It seems that Broderbund Print Shop 20 Deluxe for PC is for Windows 98 / 2000 / Me / XP.
What you can try:
1. De-install Print Shop
2. Re-install Print Shop in the Windows XP Compatibility mode.
tip
How can I print what appears on the screen completely?
Many web designers are conscious of the fact that some people will want hard copies of their web pages. For these sites, you can just print in regular "portrait" mode. At other sites, however, part of the text gets chopped off in regular page orientation. Before you print anything it is a good idea to preview the page first. Just go to File / Print Preview .
There you can make sure that everything will print correctly. If you see that part of the page will be cut off, just click the " Page Setup " button (it looks like a page with a gear on it) or use the keyboard shortcut Alt+U.
You can then change your page layout to landscape. Your browser is, after all, in landscape format, so why not go with the flow. Go down to where it says "Orientation" and click the radio button next to "Landscape".
Print Preview will change to show the new layout. Is everything there now
UNABLE TO PRINT LANDSCAPE AFTER 1: OPEN SPREADSHEET FILE 2: GO TO PRINT 3: GO TO PROPERTIES 4: GO TO PAGE SET UP & CLICK LANDSCAPE 5: GO TO PRINT PREVIEW(DOES NOT SHOW OR PRINT LANDSCAPE)
You need to change the page layout within excel set it to lancscape.
for excel 2007
Look along the top ribbon and click on "Page Layout"
then select "orientation"
and change to "Landscape"
2answers
A word document that is showing portrait orientation in print preview is printing in landscape orientation
You need to change the orientation in the printers screen.
Start>Control Panel>Printers
Select your printer
Properties>General>Printer Preferences>Page Setup
Click on Portrait>OK
Your printout should now be in Portrait mode.
My HP PSC 1200 printer has started printing all landscape documents as portraits and visa versa. Reinstalling has not helped.
hi
goto the control panel-->printers and faxes and do a right click on the printer icon.now goto printing preferences and change the settings as per your need
there is also a check box for showing the preview before printing,check that ,now everytime you want to print something it will show you a preview in advance for how the print out's gonna look like
you can change the settings as portrait or landscape by going to printing preferences.
hope this helps
1helpful
Printing in landscape
Hello sir; the problem is on computor side when click print you better click print preview then go to set up what you want.
Samsung 4216f doesnt print landscape, Vista 64
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Printing 2 pages on landscape document
Usually if you see the page in the Publisher window is already landscape, it will go landscape in the Printpreview and also in the print out. I just try to imagine what is your problem.
If I am not mistaken, this is what you did:
You have two "small" pages (maybe A5??) and you want to print it in one page of A4. Of course the A4 should be landscape.
Publisher does not have the facility to set 2 pages A5 in one A4 like in Microsoft Word.
The easiest way is just create a new page with A4, then copy the 2 pages (or you called it flyers) and paste it in that A4 landscape page.
Publisher can do print 2 pages A5 in one sheet A4 but the arrangement is as booklet. You can see the choices in File --> Page Setup --> tab "Layout" --> scroll the Publication type.
I do print 2 pages A5 in one sheet with many variations using addition software named "Clickbook".
Let me know if I m wrong in interpret your problem.
Can't print landscape?
Make sure the correct printer driver is installed.Check your user guide.Read the information below.
Printer Settings
You can use the printer properties window, which allows you to
access all of the printer options you need when using your
printer. When the printer properties are displayed, you can
review and change the settings needed for your print job.
Your printer properties window may differ, depending on your
operating system. This Software User’s Guide shows the
Properties window for Windows 98.
Your printer driver Properties window that appears in this User’s
Guide may differ depending on the printer in use.
If you access printer properties through the Printers folder, you
can view additional Windows-based tabs (refer to your
Windows User’s Guide) and the Printer tab (see “Printer Tab” on
page 10).
NOTES:
• Most Windows applications will override settings you specify
in the printer driver. Change all print settings available in the
software application first, and change any remaining settings
using the printer driver.
• The settings you change remain in effect only while you are
using the current program. To make your changes
permanent, make them in the Printers folder.
• The following procedure is for Windows XP. For other
Windows OS, refer to the corresponding Windows User's
Guide or online help.
1. Click the Windows Start button.
2. Select Printers and Faxes.
3. Select your printer driver icon.
4. Right-click on the printer driver icon and select
Printing Preferences.
5. Change the settings on each tab, click OK.
Layout Tab
The Layout tab provides options to adjust how the document
appears on the printed page. The Layout Options includes
Multiple Pages per Side and Poster. See “Printing a
Document” on page 6 for more information on accessing printer
properties.
Orientation
Orientation allows you to select the direction in which
information is printed on a page.
• Portrait prints across the width of the page, letter style.
• Landscape prints across the length of the page, spreadsheet
style.
• Rotate allows you to rotate the page the selected degrees.
Layout Options
Layout Options allows you to select advanced printing options.
You can choose Multiple Pages per Side and Poster.
• For details, see “Printing Multiple Pages on One Sheet of Paper
(N-Up Printing)” on page 12.
• For details, see “Printing Posters” on page 13
1helpful
Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
