20 Most Recent Broderbund PrintShop Pro Publisher Deluxe 20 for PC Questions & Answers
You will need some special software to print to a pdf file. A popular and free one is cutePDF. You can download it here:
http://www.cutepdf.com/products/cutepdf/writer.asp
Once you have it installed, open up the file you want as a pdf and then go to print it like you would if you were going to send it to a printer. Once the print window pops up change the printer to "CutePDF writer" and then click print. It will ask you where you want to save it and voila...your file is now saved as a pdf.
font.f1 {font: 12.0px 'Lucida Grande'; color: #000000} --------------------------------------------
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Broderbund... | Answered on Jun 28, 2011
I installed print shop and it comes up DB Access Failure
How do I fix this?
Broderbund... | Answered on Dec 07, 2010
Ok, well there are quite a few picture resizers out on the 'net. These allow you to Resize the image adjust picture "Depth" and save as differing Formats too.
One such program is Picture Resizer, by Microsoft, installing this gives you a Menu, under the Right Click, menu, that allows you to select and adjust the pictures.
Go below and download the Power Toy... Install as Administrator, and if required set to Compatibility Mode for XP SP2.
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
master Google link, for Picture resizer freeware below.
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=picture+resizer+freeware
Broderbund... | Answered on Oct 12, 2010
Go ahead and restore your system to a previous date when it was working...you would be able to retrieve it and to do so
Click the start button on the windows screen (bottom left corner)
Click all programs....click accessories...click system tools and click on System restore
On the system restore screen click next and select the previous date when you had all the project in the working condition...then click next...let the system restore get completed...it would require a restart.....that's it
Upon restart you would be able to access all the file...
Thanks
Broderbund... | Answered on Sep 30, 2010
check the properties when you export it or use another format like tif if you want higher quality
Broderbund... | Answered on Sep 21, 2010
if you look in Task Manager under Processes tab and if it's listed more then once if it is highlight it then END TASK. if not then restart your computer and try installing once more.
Broderbund... | Answered on Sep 02, 2010
just go to control panel, add remove programs, select print shop (change) and select modify it will allow you to change content to hard drive and not cd.
Broderbund... | Answered on Jun 04, 2010
Examine disk #2 for any scratches or finger marks. These can be cleaned of with a mild detergent and water, drying the disk well before using again. Scratches may be polished off with white toothpaste on a soft damp cloth. Keep the paste wet and polish quite vigorously. When finished and all scratches gone, wash away the paste and dry as above. Do not place disk/s in sunlight! Alternativly, obatain a replacement disk form Broderbund.
Broderbund... | Answered on Apr 02, 2010
You have to choose area effects tab first, click on the area (aprox) where you are going to crop, then choose crop and orientation tab and do your croping. I don't know why it works like this, but this has solved the problem for me.
Broderbund... | Answered on Mar 25, 2010
try using foxit pdf software. Thats an excellent pdf reader, writer and orgnizer tool. You can find it with crack easily. If u can;t gimme a mail at smb_146@yahoo.com n i'll send you the download links or torrents. THANX
Broderbund... | Answered on Sep 14, 2009
you can always use character map. Go to Start Then All Programs
Then Accesories
Then System Tools
and you will find character Map choose the letter you want and copy it & paste it =)
Broderbund... | Answered on May 01, 2009
TPS Window Appears on Print Shop® Splash Screen Description Solution When attempting to open Print Shop® 20, a TPS window opens on the Print Shop® splash screen. The only option available in the small TPS window is to click OK. This issue occurs when Microsoft® .NET Framework 1.1 has been uninstalled. Reinstalling Microsoft® .NET Framework 1.1 will resolve this issue. View the remainder of this technical note for the instructions. Complete these steps:
  1. Close all windows and programs and return to the desktop.
    NOTE: If the TPS window is still open on the desktop, click OK. The Print Shop® splash screen will close.
  2. Insert the Print Shop® 20 DVD or Install CD into the proper drive.
  3. Double-click the My Computer icon. For Windows® XP, click Start and click My Computer.
  4. Right-click the CD/DVD icon that represents the drive where the disc was placed and click Open. The contents of the disc will display.
  5. Double-click the Setup folder.
  6. Double-click 1033dotnetfx.exe. The installation of Microsoft® .NET Framework 1.1 will begin.
  7. Review the License Agreement, click to place a dot by "I Accept" if the agreement is accepted and click Next.
  8. Click Install to install the Microsoft .NET Framework 1.1.
  9. When the "Installation of Microsoft .NET Framework 1.1 is complete" message appears on screen, click OK.
  10. Launch and use Print Shop® 20.
Broderbund... | Answered on Apr 25, 2009
hi
pls install the pdf convter
Broderbund... | Answered on Apr 07, 2009
JPEGs were only really intended for monitor display, although they do print up on a home inkjet very well. They should not really be used for any kind of long term storage other than as original image files if that is how they were shot, as every time you save them they degrade due to the compression process used. If you are working in photoshop I would leave them in psd format, especially if you have any layers. Your edited files will store well long term as either psd or tiff files. Tiff supports layers but again unless you need to print them commercially psd will suffice.
Broderbund... | Answered on Jan 07, 2009
Broderbund PrintShop Pro Publisher Deluxe 20 for PC Logo
37 questions posted
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Broderbund Computers & Internet
Most Popular Question
39 t save doc as pdf
  • Computers & Internet
