Attached this type. to computer & print data from computer which Printer has to be select from directry from. Pc.
Go to http://www.manualowl.com Click on tab MANUALS Click on product brand name for free PDF Hopefully, manual has additional info regarding connection. Hope this helps. Jimmy
Tryhttp://www.manualowl.com
Jimmy
SOURCE: Brother CE-70 typewriter. Was typing
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
SOURCE: Brother CE-70 Typewriter: Seeking replacement LCD.
I have an external memory unit for the CE-70 [great machine; I ran my small business with four of them yrs back]. The unit is called a Brother MD-200 and I actually have some old diskettes for it. It plugs directly into the typewriter and gets its power from the CE-70. Is it worth something to you?
SOURCE: Electric typewriter just aquired. Brother CE-70
Go to brotherinternational.com, click on support. Poke around in there you will find a manual for your T/W.
Dickyo
Testimonial: "the only lead from a veritable maze of misleading merchants!"
SOURCE: typewriter ,brother ML100 STANDARD : I
Turn the machine off and allow it to rehome itself. If that doesn't help the printwheel homing pawl is probably broken. you will need a tech.
DickyO
If you were able to print
over your network but have suddenly lost this ability Brother has designed a
utility to assist in restoring printing capability with minimal user
interaction. This utility will automatically locate and update your
printer's network address within your printer driver which will restore your
printing ability!
This utility is available
for Windows 2000, XP, Vista, and 7.
To download and use the
Network Connection Repair Tool, follow the steps below:
1.
Make a temporary
folder on your computer's hard disk as the location to save this
file.
2.
Open an Internet
browser and browse to the following link. We recommend using Internet Explorer.
http://www.brother-usa.com/downloads/
3.
Choose your
Product Group, Model, and click View.
4.
Click on the link
under Your Results.
5.
Under Step 1:
Select OS, select your operating system.
6.
Under Step 2:
Select Language select your language.
7.
Click on the
SEARCH button.
8.
Scroll down to the "Network Connection Repair Tool" and click
on Information & Download
9.
Click on the
Download button.
10. On the Software End-User License
Agreement page click I ACCEPT if you agree to the terms.
11. Click SAVE.
12. You will be prompted to save the file
again. Browse to the folder you created earlier. Double click
(My) Computer => Local Disk (X:) => Brotemp and click
SAVE. The file will download.
13. Once the download is complete, click
OPEN FOLDER or browse to the folder where you downloaded this
file.
14. Locate and double click on the
nettool_XXXX.exe file. A zip self decompression window will launch,
click on DECOMPRESS(X).
