Hello all, For the past few days I have attempted to scan and save documents as pdf files using a...
(More)
Hello all, For the past few days I have attempted to scan and save documents as pdf files using a Brother MFC-7820N all-in-one printer. But when I check the designated folder for my scan, the document is not there. These are the steps I take before I scan. First I open up the ControlCenter program. I click on "Configuration" then "Scan" to configure my scans so that they are saved as PDF files and to verify where the scanned document will be saved. Next I press the "Scan" button then the down arrows to program the machine to "Scan to a File." Then I press the start button. I follow the instructions as provided on the website to the letter but it's as if nothing happened. I know that the machine is hooked up to my computer because a scan in progress window pops up after I press the start button. It should be noted that when I first used this machine to scan, there were no problems. I have even set the machine to scan and open the image to Paint without a problem. If anyone can offer some advice, I would be very appreciative.
I have the Brother MFC 7820. All of a sudden, any time it pulls the paper in from the top tray (to...
(More)
I have the Brother MFC 7820. All of a sudden, any time it pulls the paper in from the top tray (to scan or fax from the feeder), it jams and reads "paper jam". Seems to me like the rollers may have stopped working and they no longer can pull? There is no other paper jam anywhere that I can see. It prints just fine! It only happens when I need to fax or scan...whether it's one sheet or more, it just won't pull it all the way in and around. It pulls the paper part way in and then stops and reads "paper jam".
There is a broken part in the bottom tray...the part that would hold the paper in place...located in...
(More)
There is a broken part in the bottom tray...the part that would hold the paper in place...located in the center back of the tray (it should slide and lock in place, but is broken and pops out so the paper doesn't feed correctly). Can we get a replacement for this?
We have the all in one MFC-7820. It constantly has accordion style paper jams. If we move or...
(More)
We have the all in one MFC-7820. It constantly has accordion style paper jams. If we move or accidentally bump the machine, the toner powder spills out.
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks...
written by fastrepairguide
Printer would not feed paper no matter how many sheets were in the bin or how clean the printer. I even cleaned the roller. The issue was I just...
written by Viper-xp
Many Epson Printers that reach an End of Life counter number will lock your printer down and force you to contact a Service Center. However, this is...
written by worldvet
This works with most canon printers and can fix these problem 1.) Printer Not responding 2.) WASTE INK COUNTER FULL 3.) Waste resivour full 4.) Other...
written by DARKLORD1
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Using recycled ink cartridges in your ink-jet printer is never a more economical way to do colour printing, unless you are willing to become a master...
by Soulvisitor
Printer ink is one of the most expensive things that you'll run into when you set up your home office. You start out taking dozens of pictures with...
by wikihow
With all of the color printing that people do nowadays, its hard to find ways to print inexpensively. There are ways to reduce printing costs on...
by wikihow
Have you ever wondered if your printer has run out of a colour? Here's a simple way to check.
Steps:
1. Go into Microsoft Word.
2. Create four small...
by wikihow
'Resetting' your Lexmark x3350 All-in-One
So I tried using my Lexmark today... the power button is constantly on, and it won't do anything, My...
by TTonyTigger
Celebrating 14 Years Of Outstanding Printer Repair And... Read More
Celebrating 14 Years Of Outstanding Printer Repair And Designjet Plotter Repair. Serving Nationwide,Serving your Area, Get Local, On Site Certified Printer Today......
Elite printer Services, Inc. is a full service HP & L... Read More
Elite printer Services, Inc. is a full service HP & Lexmark repair facility. We repair, service, sell HP & Lexmark printers and most name brand scanners. We perform maintenance and repair HP Plotters as well. We sell New Compatible and OEM toner for all printer devices. Email us for a quote or serv
Accram is now one of the largest nation wide mai... Read More
Accram is now one of the largest nation wide maintenance service providers in the US. Headquartered in Phoenix Arizona, Accram has earned a reputation for unsurpassed customer service. Our business motto is: Uptime, All the Time. At Accram, we live and breathe our business motto
